Old 24-Jan-2005, 11:27   #1
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Split fork
It's as painfull as it sounds!!!!!!!!!!!!!!!!!!!!!
Went to put my bike back together after a long winter of cleaning it and I have noticed that the left hand forkhas a split in it
It is about 10mm long and goes right to the edge of the fork.
I've had the bike about 6 to 8 months and have never noticed it before, where do I stand legally (if anywhere) with the shop I bought it from or with Ducati as it could be a fault.
The bike has not been abused and I've covered less that 2000 miles (as I was saving for a big service)
Any idea how much this will cost to repair.
Old 24-Jan-2005, 11:35   #2
Braai Boy Braai Boy is offline
Mood: No! No! No! erm OK then
Can you post up a pic so we can get a better idea?
Old 24-Jan-2005, 11:36   #3
Felix Felix is offline
Where exactly is the split? Can you post a picture or describe it further?
Old 24-Jan-2005, 11:39   #4
dave996's Avatar
Mood: Fed up...
I'll go take one now.
TTFN
Old 24-Jan-2005, 12:11   #5
dave996's Avatar
Mood: Fed up...
Old 24-Jan-2005, 12:18   #6
Harv748 Harv748 is offline
Harv748's Avatar
Its difficult to see in the piccie, but I assume its the area just above the fork bottom.
That kind of thing, although I've never seen it before, looks like either some form of manufacturing fault or something that has been caused by the forks suffering from some form of impact at some point.
Could you give us some more details on the bike...age/history etc. You say its only dome 2000 miles, is that from new?
If its a manufacturing fault then I would say you had a good case against Ducati for a replacement FOC irrespective of if the bike is out of warranty or not. If there is an issue of possible past crash damage...then obviously not!
Any chance of a couple of clearer pictures.
Old 24-Jan-2005, 12:29   #7
dave996's Avatar
Mood: Fed up...
Sorry I wasn't clear...the bike has done 11k but I have only done 2k, I've had the mudguard off before and I never noticed it and a duc mechanic up in Lincoln has had the wheels out of it and given it a good look over and had not noticed it.
It's a 1999 996, I am the second owner and it has not been crashed as far as I'm aware, it's not been around the track or wheelied and no stoppies.
It was bought from Hughenden M40 m/c just off of the M40/A329 (you might know it)
I'll go and take some better pictures.
Thanks for the reply
Dave
Old 24-Jan-2005, 12:36   #8
keefer keefer is offline
keefer's Avatar
That's real strange.
I have never seen a fork leg like that ?
is there oil coming out or is it just the plating that's gone strange ?
first impression was impact damage. but difficult to see
Old 24-Jan-2005, 12:39   #9
If it was an actual crack then you would expect oil to be coming out i would have thought. Maybe someone has used a screw driver to get the oil seal out at some time and its cracked the anodising which is now lifting away as the leg corrodes under it.
Second hand standard forks appear on Ebay quite often for not much money.
Old 24-Jan-2005, 12:41   #10
dave996's Avatar
Mood: Fed up...
here's 1
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:06.
