Old 09-Feb-2005, 14:49   #11
khu996 khu996 is offline
khu996's Avatar
Sorry about the slow update. Ive removed the two small screws, and a small circular plate drops out, but it doesn't release the catch system.
Any other ideas Skids?
Old 09-Feb-2005, 14:54   #12
Why not remove your cap from your existing tank so you can see what else might need removing?
Can you not actuate the catch from the inside...
Worst case scenario sell it.... (to me! )
Old 09-Feb-2005, 15:12   #13
DSC Member AK AK is offline
AK's Avatar
Mav, thats one I havent heard - the lazer key thing - will tell Alan.
The last tank he bought had the same prob - but he phoned around first to find out costs for the replacement lock (not as expensive as he first thought) - and then drilled out the tumblers to get existing one out.
Khu - hope you get it sorted - try here???
http://www.studios92.com/guide/locksmith.htm
Old 09-Feb-2005, 15:17   #14
khu996's Avatar
Thanks CK. Wanted to try some other clever method before I took to drilling it out. If worst comes to worst, thats what it'll have to be.
Old 09-Feb-2005, 15:36   #15
You should be able to just push the locking piece in (it's only held in by a spring!) and this should flip the cap up. Works on all the old ones...
Old 09-Feb-2005, 15:40   #16
It's a different filler cap on the 749/999.... same as the Uglystrada...
There's effectively 2 holes, one for fuel and one for the locking mechanism, which has a plastic cover between the catch/lock and the fuel, I'm guessing if he's managed to get that off from the inside he should have access
Old 09-Feb-2005, 16:35   #17
Ok, I know what you're saying but fundamentally the locking machanisms are exactly the same. Just push on the latch and it should pop up...
Old 09-Feb-2005, 16:49   #18
The problem I see is the cover though will be blocking the lock from underneath, coupled with the fuel pump being right at the back of the tank, near the seat pad
Old 09-Feb-2005, 16:52   #19
It does look very nasty indeed!
Old 09-Feb-2005, 16:56   #20
Thus why I have a nice trick JHP billet one
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:10.
