Old 15-Feb-2005, 20:02   #11
dave w dave w is offline
dave w's Avatar
Mood: My K5 Rocks !!!!
Originally posted by DucSoon?
Originally posted by dave w
Sounds about right for the rear part... The front part of the seat unit is around £350
Not to sure why you just need the rear part.
The rear mono cowl will not fit on a bip front section.
So the tail has two parts?
And if i want to turn a biposto into a monoposto i need those two parts and not only the tails unit Gareth is talking about?
There are 2 parts of the seat unit.... The front and the back... for mono and bips....These units are not interchangeable between the two....So if you have a bip and your want a mono seat unit then you need a new subframe and seat unit
Old 15-Feb-2005, 20:07   #12
Ducnow Ducnow is offline
Originally posted by sparkin
To convert to mono you`ll need more than just the plastic bit,the Dodgy Greek done his with genuine Duc bits off ebay and the cost was nearly half a grand
You`ll need the two parts of the plastic seat,subframe,bum pad and a few odd fastners.
Ducati do a MotoGP style converter to single seat which requires no subframe change,not sure of the cost thou.
Wow, WTF!!
Now i'm ****ed
So even the subframe and bum pad are different???
I thought you had to change the subframe (and ges some passanges pegs) if you wanted to do the mono to biposto conversion, but not the other way around
Old 15-Feb-2005, 20:08   #13
sparkin sparkin is offline
sparkin's Avatar
Originally posted by Green1
Why bother with that....., when you can buy a ducati corse FO4 - actual un-painted version from Sandbar Ltd - around £350 ish ?? Looks the nuts , when you finally suss out how to fit it.
When the greek done his they weren`t avaliable,if you add a quality spray job to the unpainted unit from Nigel(sandbar ltd,good stuff is that)you`re getting near the same money,it just depends which style you like
Old 15-Feb-2005, 20:08   #14
Ok that had already answered my question, thanks.
Wow, i'm ****ed
Old 15-Feb-2005, 20:12   #15
dave w's Avatar
And the bad bit is £500 + VAT for the mono subframe.
Old 15-Feb-2005, 20:15   #16
sparkin's Avatar
Don`t give up hope,the Moto GP unit Ducati do is painted and fits straight on to your subframe,I think it`s around £300.You think the 749`s bad,you should try changing the seat on a 888
Old 15-Feb-2005, 20:31   #17
Going from bad to worst....
But why doesn't it fit? Just so Ducati can sell the whole set, huh?
And are there some nice mono aftermarket plastics that do fit the biposto configuration?
Old 15-Feb-2005, 20:32   #18
Yeah, but it's a Moto GP style, right?
Different from the 999's ones.
Old 15-Feb-2005, 20:43   #19
sparkin's Avatar
Try this one
http://www.spareshack.com/cgi-bin/br...up=74999 9bod
Old 15-Feb-2005, 20:45   #20
sparkin's Avatar
Or this one,you`ll have to scroll down
http://translate.google.com/translat...8%26oe%3DUTF-8
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:41.
