Old 11-Mar-2005, 09:31   #11
If it's in the final coat it should rub out no problem with 1500 wet and dry.
I've got a couple of dogs and had a similar problem, but you'll find that you can often work the wet and dry to get one piece of the hair sticking out and then pull it out with tweezers.
Sounds stupid but it worked for me. On the other hand, I only had a few stray hairs blow onto the drying lacquer, not a big clump.
Old 11-Mar-2005, 11:35   #12
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Mate showed me a nice track when we had a similar drama. Use a piece a masking tape. Hold it sticky side down and just touch it against the offending hair, fluff, bit of muck; need to be quick while the laquer is still wet. Leaves a tiny mark that's easy to buff out.
Rgds, Rob
Old 11-Mar-2005, 11:47   #13
chief chief is offline
chief's Avatar
Mood: Either bemused or indifferent
hooley,
Is that like having hair on your sweetie?
Old 11-Mar-2005, 12:11   #14
hooley hooley is offline
hooley's Avatar
Mood: One day I'll be allowed out to play......
Chief - good analogy
Rob - a bit too late for that as it's fully cured now. Also it was more than one hair
Just started the rub-down, then will probably re-laquer a final coat, locking the door so the (now bald) cocker spaniel cannot cause more mischief
Cheers all
Jas
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:19.
