Old 22-Apr-2005, 14:51   #11
And yes, that does look lovely.
Very nice work!
Old 22-Apr-2005, 14:52   #12
fil2 fil2 is offline
fil2's Avatar
Mood: is it still wet
Originally posted by antonye
Phil -
Mine took about 3 days to arrive, but I was the first one in there and I think the others had to wait for stock.
The seat unit uses original mounting brackets (the 4 at the front) but it sits above the frame, so you either have to use a Ducati fitting kit (about £40 I think) or make your own...
http://horrible.demon.co.uk/brackets/
cheers Antoyne
Old 22-Apr-2005, 14:55   #13
paynep's Avatar
Mood: Wet wet wet
The seat took under a week to arrive.
I bought standard Superlight seat mounting plates from Snells and discovered that the rubber blocks that sit between mounting plate and frame are identical to the tank locating blocks - and I had a gash tank with a set of blocks so it was easy.
Tony Brancato sells it all as a kit, too.
Or do what I do with my 888, put some pipe insulation on the frame tubes and glue a strip of rubber onto the seat unit so that it sits on the frame rails.
Cheers, Paul
Old 22-Apr-2005, 16:10   #14
Felix Felix is offline
That looks proper, Paul. Nice one and good luck.
Old 22-Apr-2005, 16:11   #15
Monty's Avatar
Very pretty Paul-but wouldn't it have saved time to have painted it dusty gravel colour to start with..............
John
Old 22-Apr-2005, 16:36   #16
psychlist's Avatar
Mood: Lucky? For some, maybe!
Very well presented Mr P! I'll lay odds she goes as well as she looks too
I've seen several very well turned out machines all ready to go for DD, I shall be embarrassed to ride on the same piece of track as you lot so I think you should all ride about a half a lap behind
Old 22-Apr-2005, 18:47   #17
Jamcoly Jamcoly is offline
Jamcoly's Avatar
Mood: starting to feel better
half a lap in front Paul
Old 22-Apr-2005, 19:11   #18
monstermob 998's Avatar
Nice work paul- i'll see you cadwell next week
Old 25-Apr-2005, 19:32   #19
paynep's Avatar
Mood: Wet wet wet
Home safe and sound - unlike my mate who got the second part of Charlie's wrong and ended up in the tyre wall - but unhurt.
Lap times nothing too spectacular, but the bike was running weak at the top end so the straights were a big yawn and the steering head bearings are definitely shot so braking was a bit of a lottery.
Plenty of time to sort that before the weekend - if not I'll be using all you fast guys to stop me!
Old 25-Apr-2005, 22:16   #20
domski's Avatar
You were looking smooth at Cadders. I followed you for a lap or so on the black 748.
Your bike looks pretty too
[Edited on 25-4-2005 by domskidue]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:52.
