Old 31-May-2005, 13:31   #11
I have this on my 600 monnie, thought the brake is stickin on but doenst seem to be, but is does squael a bit when stopping...any clues?
Old 31-May-2005, 19:25   #12
L3OONY L3OONY is offline
Mood: Mildly reckless...
Just had the same on my 748R. Resulted in me replacing the pads (which are part of the caliper) and a disc.
Think the caliper was also available from Spondon Engineering, about £50 + vat and is brembo.
Have been told that is fairly common, if that makes you feel any better...
Old 31-May-2005, 19:32   #13
Yep, I've got this on my ST as well.
Since I never, ever, never, ever use the back brake I don't even bother bleeding it until MOT time. The MOT was last week and now my back brake is sticking on.
Could be that I've overfilled the reservoir when bleeding the brake or it could be that, since I never use it, the pistons are just stuck. Either way I don't think it's anything that a good clean and grease up can't fix.
Old 01-Jun-2005, 10:28   #14
sharpo sharpo is offline
sharpo's Avatar
Mood: Big bill-money well spent
Plenty to go at there thanks.
I've been doing the garden for three days but I'll sort the bike before Croft on sunday.
See ya there
Old 01-Jun-2005, 11:30   #15
HW HW is offline
I had this problem on an ST2. Once you get into the loop of overheated rear brake it is hard to sort it because the following tends to happen:
Boil the fluid with heat passed back through the caliper
Heat buckles the disk causing small amout of friction
The heat build up causes the fuild to heat up and expand - if it is overfull then it has no where to go and the pads squeeze the disk enough to increase the heat, etc etc.
I'm sure you problably get the picture.
As for cleaning the pistons, I was also told a little brake fluid on a clean rag was the way to go. Shouldn't need grease, and definately not copper grease. The red stuff you refer to sounds like "Red Rubber Grease" and is worth having a tin of around. Our local dealer uses that for everything from electrics to 749/999 coil seals to well nuts - it's pretty safe. Not sure about how it might react with brake fluid on the pistons though.
Thinking about it - remove the caliper from the wheel and push the pistons out a little. Be careful not to push one ALL the way out - it is possible I did it on the ST2 and a sod to get back in. Wipe around the piston before it goes back in then alternately lever them back in and use the brake lever to push them out again. Sometimes hard to get both to work because one will move easier than the other. That might be the problem then in fact, one sticking piston.
Hope some of that helps, and does not confuse too much. Head full of cold so I am rambling even more than usual!
Old 09-Jun-2005, 18:46   #16
bostrom998 bostrom998 is offline
bostrom998's Avatar
Mood: Long on Duke's...so happy
You mean the rear brake actually does something.................can't believe anyone really believes that. Last three 916/998's I've had you might as well have been stomping on a piece of wood for all the good it did!!!!
Old 09-Jun-2005, 19:01   #17
HW HW is offline
On the ST2 it certainly did something ... I ended stopped at the side of the road wondering why I could not move.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:10.
