Old 21-May-2005, 15:27   #1
sharpo sharpo is offline
sharpo's Avatar
Mood: Big bill-money well spent
Rear disc running very hot
I have noticed the rear disc is very hot even if I stay off the rear brake, what can cause this on the 916.
I've bled it and the pistons don't appear to be sticking but they are bone dry, would a little copper grease help em retract or what.
Thanks for your reply you font of all knowledge.
Old 21-May-2005, 15:45   #2
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
I had that hapen to me I found that although I wasn't using the rear brake I was resting my foot on it put a bit more free play in it, worked for me.
Chass
Old 21-May-2005, 19:54   #3
Dont put copper grease on the pistons, you need special brake grease.
Old 22-May-2005, 10:22   #4
sharpo's Avatar
chass i'll give it a go
rockhopper how "special"
Old 22-May-2005, 15:10   #5
erm, something in a tin labled "brake grease"!! Its got to be safe on the rubber seals. Copper grease contains tiny bits of copper so you shouldnt use it on moving parts as it'll wear them away!
Old 22-May-2005, 21:13   #6
sharpo's Avatar
I'll be buggered "brake grease" why dint I think o that.
If it's that red stuff we've got it at work, but i'll buy me own of course
Old 29-May-2005, 18:38   #7
Go Galfer Go Galfer is offline
Couple of thoughts would be that the resevoir is over filled or possibly that you need to rebuild the calipers and master cylinder.
Old 29-May-2005, 22:01   #8
sharpo's Avatar
I'm gonna strip it down and clean everything, I've been told they don't sell the seals though ?
A new caliper is only £60 right ?
Old 30-May-2005, 20:15   #9
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
£69.72 including the VAT from On Yer Bike . Remember the heat from the Exhaust does get the master cylinder reasonable hot and if the fluid resovior is to full stops any expansion. Also, the adjusting rod that fits into the rubber grommet on the master cylinder it should be able to be withdrawn enough to allow the fluid to return back through the seal plunger. I had too replace 2 calipers within a month because of this . So dont try to have to little rear brake travuss on the foot lever. There do not sell parts only for Brembo brakes . 4D
[Edited on 30-5-2005 by Fordie]
Old 31-May-2005, 12:51   #10
Webcore Webcore is offline
Happened to me - the rear master cylinder was knackered - the pedal wasn't returning properly - ended up costing me a disc, caliper and master cylinder. New seals/master cylinder should cure it.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:05.
