Old 20-Jul-2005, 22:30   #11
rob748b rob748b is offline
rob748b's Avatar
Mood: happy dayz!!
Yep posotive it is oil, still wet on the V-Peice it is all cleaned off now and will see how it goes but a bit worried about riding it incase something else goes!!
Old 20-Jul-2005, 22:32   #12
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Rob, have you got any oil running down your forks?
Old 20-Jul-2005, 22:34   #13
rob748b's Avatar
Mood: happy dayz!!
Nope checked all of that aswell mate, there is no oil running anywhere as far as i can see, got all the panels off had a good look round and can see nothing wrong anywhere, just oil on the v peice and on the inside of the right lower fairing , totally confused!!
Old 20-Jul-2005, 22:34   #14
748IOM 748IOM is offline
Mood: Yellow!!
Just ensure it's clean up as you've done, ensure oil is at the right level and then just keep an eye on it, thats all you can do.
Unless it suddenly starts spitting it out then I can't see anything to worry about.
Worst case it'll be a weeping gasket anyway so no real biggy, may even be that the head gasket that was replaced hasn't seated tightly enough, but if you've checked it for weeps then it may not be that.
I assume you've checked all gasket joins for weeps.
Old 20-Jul-2005, 22:36   #15
rob748b's Avatar
Mood: happy dayz!!
Yes mate done all of the above, just a bit confused as to where it has come from, maybe its my bike telling me to clean it more often!!??
Old 20-Jul-2005, 22:37   #16
dave996's Avatar
Mood: Fed up...
[totally confused!! [/quote]
Wots new:P
Old 20-Jul-2005, 22:38   #17
rob748b's Avatar
Mood: happy dayz!!
hee hee your'e so funny dave!!!
Old 20-Jul-2005, 22:55   #18
Mood: Yellow!!
All I know is I used to worry about every little thing about my bikes in the past and over time, just learnt to not worry about things as much.
Still be diligent and ensure everything is kept clean and topped up, bike warmed up correctly and serviced regularly.
Outside of that all there is left is to enjoy it
Old 20-Jul-2005, 22:58   #19
rob748b's Avatar
Mood: happy dayz!!
Not had any problems with the bike before this last week or so, so have been lucky really, just hope nothing major is on its way thats all!!
Cheers for all of your help much appreciated!!
Old 21-Jul-2005, 00:15   #20
mogwai mogwai is offline
mogwai's Avatar
Mood: IF IN DOUBT..GET BLAGGING.
Check your oil cooler hoses,if their the original duke ones,they are prone to splitting on the sleeve bit,mine have been misting out for a while and have now started to **** out...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:22.
