Old 10-Aug-2005, 16:43   #11
I don't think that the Bipostos had adjustable steering heads either...
Old 10-Aug-2005, 16:44   #12
Mr_S Mr_S is offline
Different engine as well in the E
Heads are totally different to the rest of the 748's, but the same as on the 600 monster & SS (IIRC)
[Edited on 10-8-2005 by Mr_S]
Old 10-Aug-2005, 16:48   #13
Adjustable on the '97 bip in my garage
Old 10-Aug-2005, 17:00   #14
Monty's Avatar
Interesting since the 748 is a watercooled 4 valve and the 600 monster and SS series are 2 valve and air cooled??
John
Old 10-Aug-2005, 17:02   #15
John
Talking steering heads here mate,do keep up.
Old 10-Aug-2005, 17:40   #16
Not really, I was actually referring to the cylinder heads.
I do believe I got the models wrong, but the 748E does have a stepped head for the front cylinder. Whereas other 748's do not, and this means they're not interchangeable.
This was so that they could use a common engine for other bikes (stepped head is required to provide clearance for the front wheel)
Old 10-Aug-2005, 18:29   #17
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
The stepped head is actually for clearance for the frame / suspension rocker mount by the exhaust side of the vertical cylinder head on the ST's frame....
The exhaust cam is 5mm lower.
The 748E uses the same head castings ( although different valve sizes ) as the ST4,4S, Monster S4 and S4R.
Old 10-Aug-2005, 19:52   #18
Do you know how long I've just spent getting that info, and you'd posted it over an hour ago.....
Doh!
btw,
Chris, if you're unsure about fitting the QR couplings, there's bound to be one of us nearby who'd help out. Just let us know where you are.
Old 10-Aug-2005, 20:10   #19
The OE Ducati fittings are scary money.........£40+ a pair I think. The ones in the above links should work fine. Just try and check they are ok for the pressure that fuel injection uses.
I've not seen an E using QR fittings. I think they are the only ones to do with out??
My '98 BP has adjustable head angle. Again, I think the E is the only one to lose out.
The stepped heads are, indeed as RJ points out, originally for the ST and M's. They went on the E to spread out the production costs I guess. They also use different cam belts.
Don't let the DD boys think they'll fit their 600's
Old 10-Aug-2005, 22:01   #20
cl0nd0n cl0nd0n is offline
cl0nd0n's Avatar
Can you still convert the 748 E engine to be an 853??
Will the kit fit with this different head?
As we have establisged the E does not have an adjustable head angle what else do I need to llok at changing to make this a suitable road / track bike?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:46.
