Old 29-May-2006, 20:24   #11
wato39 wato39 is offline
Mood: Saving
Originally Posted by Gaz 748
Could be 60 profile front tyre, had the same problem
changed to 70 profile, no more problems.
It is a 70 profile tyre .
Old 15-Jun-2006, 20:06   #12
adrian748 adrian748 is offline
Agree change to 70 profile front, problem solved.
Old 15-Jun-2006, 20:27   #13
Felix Felix is offline
As a starting guide, try 15 mm rear and 25 mm front static sag. Running wide usually means the rear is squatting too much in relation to the front. This can be due to a number of factors, but static sag must be checked first. After that maybe the rear ride height is too low, or the spring is too soft for your weight. How heavy are you and what's the spring rate (printed on the spring)?
Old 15-Jun-2006, 21:36   #14
Stu748R Stu748R is offline
Mood: I've just ordered a new bike and its a ..
So its not just me then..............................
Old 15-Jun-2006, 22:27   #15
GsxrAge GsxrAge is offline
GsxrAge's Avatar
Does it run a 180 or a 190 rear ?????
Old 15-Jun-2006, 22:27   #16
GsxrAge's Avatar
Old 15-Jun-2006, 22:36   #17
smilo006 smilo006 is offline
smilo006's Avatar
Mood: I like my bike
running wide
simple guide to checking suspension. Don't need a stand, get a mate to pull the bike up on its side stand. Settings in your manual provide std settings.
Old 16-Jun-2006, 08:53   #18
weeksy2 weeksy2 is offline
WAto.... get yourself down to LouigiMoto in the next few weekends with me and a few of the boys.... hoping to make it down the weekend after next. He will set up your bike so it turns amazingly.... I've ridden a 996 and a 748 recently and neither handle even close to how mine is.... Possibly if being picky i'd take 1 click off each of the back end to soften it slightly...
Drop me a pm to sort if you fancy it...
Old 16-Jun-2006, 18:47   #19
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Felix with Ohlins forks I don't think he has a cat in hells chane of getting 25mm of sag. Closest I ever got was 30mm untill I had the new converstion kit.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:03.
