Old 26-May-2006, 23:06   #1
wato39 wato39 is offline
Mood: Saving
748 r running wide in corners
Something i've noticed with my bike , first time it happened thought it was just me but its happened a few times , normal speeds all is ok ,but if i get to a corner when i'm giving it some i start to run wide then if i try to counter this by leaning a bit extra it realy feels like the front is going to tuck , its quite scary , the are tyres are diablo's and all the preasures are ok ,any thoughts ? rear ride hieght maybe ?
Old 26-May-2006, 23:39   #2
ali ali is offline
ali's Avatar
Mood: Damp
I generally find this happens when the rear ride height is set too high, but you usually notice at walking pace as the front sort of flops around.
Best bet is definitely to have someone help you with setting the suspension up for your weight/height/style. Why spend £x000 on a bike and not chuck another £60 getting it right? Try a search on the site for suitable folk to help out.
Cheers,
Ali
Old 27-May-2006, 00:40   #3
Bungi Bungi is offline
are the forks topping out? sometime you get that vauge knida straight on feel when the forks arent adjusted right.
just maybee
Old 27-May-2006, 01:14   #4
Totto Totto is offline
Tyre pressures , static/loaded sag , check them then post back , make sure all settings back to std ,ignore me if you have already done all this
Old 27-May-2006, 09:18   #5
Mood: Saving
Trye pressues are ok , but i'll check the sag ,thanks, any idea what the static sag should be ?
[Edited on 27-5-2006 by wato39]
Old 27-May-2006, 23:02   #6
Lightning Boy Lightning Boy is offline
Lightning Boy's Avatar
Mood: Waiting at the Crossroads......
First and foremost.......
What profile front tyre are you running.....60 or a 70 ?
Old 29-May-2006, 11:29   #7
Duke2BSteve Duke2BSteve is offline
Duke2BSteve's Avatar
Wink
Mine did this when i bought it, noticed it really drifting on roundabouts.. Had my front Ohlin seals and oil replaced, and this stopped the problem.
Old 29-May-2006, 13:48   #8
Smile
And prob set your front sag at the same time
Old 29-May-2006, 19:24   #9
Gaz 748's Avatar
Could be 60 profile front tyre, had the same problem
changed to 70 profile, no more problems.
748R - Less is more !
Old 29-May-2006, 20:08   #10
Brent Brent is offline
Brent's Avatar
Same as Gaz - front always felt like tucking in on the 120/60.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:13.
