Old 31-Dec-2006, 17:18   #11
9rrr 9rrr is offline
ratios
Thanks for that. All the best to you all.
Old 31-Dec-2006, 17:21   #12
There's a "sweet spot" - around 4,600 RPM @120Km/hr in 6th gear for liter displacement superbikes, a little higher for 74X's. Obviously, faster tracks will require rear sprockets with fewer teeth, slower tracks more teeth (and possibly longer chains.)
I strongly recommended NOT changing the stock front sprocket or chain size for safety reasons. Just my opinion.
Old 31-Dec-2006, 20:25   #13
MARTIN H MARTIN H is offline
MARTIN H's Avatar
Shazaam!, I used this very chart that you kindly provided earlier in the year when I changed my gearing. Only problem being the listed sprockets for the 996R are incorrect. They have a 36 tooth rear as standard. Apart from that its a great bit of info.
Happy New Year!
Old 01-Jan-2007, 02:01   #14
Thanks Martin. The data's been corrected above.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:47.
