Old 31-Dec-2006, 13:51   #1
9rrr 9rrr is offline
Changing ratios
Hi all Im thinking of changing the sprockets im running and thought id ask the question to see what the masses are running.
The Duke is fitted with a DID ERV 520 chain, Renthal 15T front and 38T rear with Renthal sprocket carrier.
The chain is mint and as its due for a service down at JHP in January, fancied changing the cogs. Bearing in mind ive heard if you go up too much you have to change the chain, (DONT WANT TO DO THAT)
In France this year with this set up I had 170mph showing on the clock. Im not bothered about the top end as in this country id end up inside.
Any suggestions
Old 31-Dec-2006, 14:09   #2
MARTIN H MARTIN H is offline
MARTIN H's Avatar
I went up 3 on the rear, the same as dropping to a 14 on the front. Made the bike much nicer to ride. Did fit a longer chain though.
Old 31-Dec-2006, 14:11   #3
ratios
So what size sprockets are you running then on the front and rear
Old 31-Dec-2006, 14:40   #4
Rick Rick is offline
IF Martin is talking about his R then its 15 front 36 rear originally so now its
15 front 39 rear
I have 15 F and 38 R with the same size chain
On the bigger bikes its better, so Ive been told to go more at the rear as it causes less stress
Old 31-Dec-2006, 15:06   #5
Bungi Bungi is offline
i run a 14 / 37, still overtakes a guy on his R1 flat out in top, and pulls away sweetly.
there are some who say not to go with the smaller front as it turns the cahn tighter, but ive never had any problems with it. chain life seems fine etc
Old 31-Dec-2006, 16:23   #6
ratio
So if I go a tooth smaller on the front to 14T and keep the 38T rear I should see a difference... yeah ?
Old 31-Dec-2006, 16:27   #7
Gaz 748's Avatar
Oh yes !!!!!!!!!!!!!! Talon make a 13 front, but it runs too close to the swinging arm. 14 will be fine
748R - Less is more !
Old 31-Dec-2006, 16:34   #8
If you do go that way let me know how it is as now I am running just a
15 front and 38 back, so curious how much of a difference it will be, if that front wheel comes up
Old 31-Dec-2006, 16:35   #9
ratio
Brill final question, how much for Renthal 14T front sprocket
Old 31-Dec-2006, 16:58   #10
bill955 bill955 is offline
£17.32+vat
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:51.
