Old 11-May-2004, 20:50   #11
This sounds like you've had the sprocket backing out of the hub which has caused the wear.
I had the same thing and just had to replace the "sprocket flange" assembly which was 30 quid from a breakers.
Have a look at my posts here:
http://217.199.188.40/control/boards...d.php?tid=6972
Old 17-May-2004, 00:22   #12
Gannet Gannet is offline
Mood: MewaaaMewaaa
I've also had this happen on my bike, but the damage wasn't too serious , all I had to do was replace one of the cush drives.
When you get new ones fitted, use a centre punch and peen the sprocket in about 3 or 4 places around the outside each of the drives as this will stop the drives working their way out and then protect the peen mark with a blob of paint.
If you don’t understand what I mean, get in contact (u2u) and I can send you some diagrams.
If you think that this procedure is a bit dodgy, the aerospace industry has been using it for years on bearings and we use it in all sorts of places in the F1 team that I work for.
Regards,
Gannet
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:12.
