Old 23-May-2004, 20:50   #11
Originally posted by Mr_S
I'm passing by Moto Rapido weds / thurs this week, if they've got these parts (probably in a cardboard box somewhere...) let me know and I'll pick them up for you and save you the journey.
Steve & the boys seem to hoard boxes of these bits so may have the stuff kicking around.
[Edited on 23-5-2004 by Mr_S]
Thanks for the offer. I'm going to give Wilf a call tomorrow and ask what hes got - hopefully pick up thgis week.
Looks like Poole is off tho, depending on if I can fix bracket
Old 24-May-2004, 10:27   #12
Originally posted by PBSPS
unfortunately, its not the arm I need but the complete headlight bracket. ... Any idea how much the frame is?
No, I've not been that stupid yet so I don't know how much one of those is
Just phone up your local dealer and ask them how much one is. Just make sure you're sitting down first!
As DJ says, keep checking with ebay as you get one on there every so often.
Old 24-May-2004, 14:41   #13
It's just a thought, but is the fact that you can't reach the ground really to do with a few mm pre-load? 9mm difference is less than half an inch.
I'm on tip toes on my ST as well, but that's only because I've got the rear ride height adjustment ridiculously high. I had it set right (lifted about an inch from standard) but crammed a bit more on when I went from a 170 to 180 rear tyre. It made no odds to the speed of steering so I've been meaning to set it back again. In the meantime, I have had a couple of near goes when I've tried to get my foot down in a hurry.
Now I know 996's have rear ride height adjusters as well...just a thought.
Old 24-May-2004, 14:44   #14
DJ Tera DJ Tera is offline
PB - how tall are you? I'm only 5ft 8 with 32" legs, the back of my 998 is jacked up nearly as far as it will go, and I can still put both feet flat on the ground, so unless you're even shorter then theres summat definitely wrong with your setup
Old 24-May-2004, 16:19   #15
more a question of how wide...ask yer mate Jewell! I am 5'8 but with one foot on the floor, my other is about 8" off the ground (at least!) hence wobbly if I dont plan ahead for stops.
I have also looked at the ride height adjuster and there is space to lower a bit. Going to have a go this week (hopefully) and see if it makes much difference. Will probably drop the front by one ring as well - then its the same as the 748 was (5 clear rings) If this fails, probably have to reverse the chain adjuster, at least this should take an inch off.
Alternatively, sell it and buy a harley!
Old 24-May-2004, 17:53   #16
Loz Loz is offline
Loz's Avatar
Don't you bl00dy dare, Paul!!!!
Get a Viagro 535 instead!
Old 25-May-2004, 12:31   #17
Mr_S Mr_S is offline
Paul,
One headlight bracket...
http://cgi.ebay.co.uk/ws/eBayISAPI.d...2858 231&rd=1
Old 25-May-2004, 13:32   #18
everton
Paul,
I'm really gutted to hear about your spill..............as DJTera says it's all about inside leg measurement. I'm 5'10" with a 31" inside leg and was comfortable on my 996 & my current 999.
Hope you get everything sorted m8. Anything I can do let me know.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:02.
