Old 16-Dec-2009, 00:35   #11
You can make anything fit with an angle grinder
Old 16-Dec-2009, 13:36   #12
MSO 749s MSO 749s is offline
MSO 749s's Avatar
Thanks for the replies. As I thought, I'll get some spares and go easy on them.
Old 16-Dec-2009, 14:37   #13
Wipe the new ones with a little grease, anything really and don't over tighten. Just bottom them and nip them a touch.
They really are a nightmare to get out on the 749/999 once the head has rounded.
Old 16-Dec-2009, 19:57   #14
bigtwin bigtwin is offline
Talking
We know all about that dont we Neil!! Sorry!
Ian
Old 18-Dec-2009, 13:07   #15
MSO 749s's Avatar
Hmmm, one is completely rounded. Was going to try a screw remover tool if it will fit in.
Unless anyone has any other ideas? Except ones involving Ankle grinders...
Mark.
Old 18-Dec-2009, 13:21   #16
Mark.
First try would be a torx bit. Tap it in and see if it bites enough to unscrew the bolt. It sounds a pain, put loosen the clip on and move it out the way for better access.
Once the head goes, it's dremel time. They really can be a pain in the arse
Old 18-Dec-2009, 15:53   #17
dunlop0_1's Avatar
As Nelly said, Dremel time. Try and cut a slot in the head so a screw driver will fit. I think they are 6mm bolts so you can get in to it drill the head off with a 6.5mm drill and the mirror will come off leaving the remainder of the bolt sticking out.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:52.
