Old 04-Oct-2011, 19:50   #11
smilo006 smilo006 is offline
smilo006's Avatar
Mood: I like my bike
unburnt fuel is ok? unburnt fuel = less power = less fun!
Old 04-Oct-2011, 20:39   #12
Presumably by "ok" he means it doesn't require new cylinders, pistons and rings
Old 05-Oct-2011, 21:05   #13
Manga Manga is offline
Bikes: Ducati 996B, Triumph Sprint ST 955i
Correct
Old 26-Jan-2012, 21:33   #14
Turns out I dont think this is unburt fuel now.
One mate thinks its a valve stem seal.
So, I may have a stem seal damaged as the bike is smoking on part throttle.
Does anyone know if the stem seals can be changed without taking the cylinder head off?
I don't have an exploded drawing showing the arrangement.
If the stem seals are pressed into the valve guides then I would think the head has to come off.
Old 26-Jan-2012, 22:33   #15
Here you go....
Old 27-Jan-2012, 18:47   #16
Thanks for the drawing.
It doesn't answer my query regarding replacing the stem seals only - ?
Old 27-Jan-2012, 21:09   #17
Alright Mr Picky!!
Old 27-Jan-2012, 22:09   #18
final_edition's Avatar
I think he maens the rubber valve stem seals rather than seats or guides.
Old 28-Jan-2012, 18:46   #19
Yes thats it, the rubber seals.
But I wonder if I should just take the engine out & check the rings as well?
I suppose a compression test will show which cylinder but won't tell me if its valves or rings?
Old 28-Jan-2012, 19:13   #20
Need a Leak down test done
Then if the pressure drops you can listen for the air leak
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:31.
