Old 30-Jan-2012, 23:07   #11
Originally Posted by Spjallen
That's one brilliant post.
+1 to that.
Old 30-Jan-2012, 23:42   #12
Originally Posted by bradders
But not relevant to our little bikes.
Not quite true - there's a lot of good information in there about the venturi effect, the plenum effect, Helmholtz resonation and filter performance which are all relevant to any bike and the power it makes as well as the way it makes it.
Old 31-Jan-2012, 00:06   #13
Also makes a difference wether your running CV Carbs, Slide carbs or fuel injection
Engines are essentially air pumps but to work they need need a air fuel ratio within a certain range. One end of the range will give good economy the other the best power.
So its not only a matter of drawing in two lots of 300cc (probably less as engines aren't 100% efficient, especially older two valve SOHC ones) 5000 times a minute but also getting not only the correct amount of fuel but also getting it to mix with the inrushing air as best as you can.
What I would like to know at exactly what point do the injectors switch on to fit in with the opening cams duration
Old 31-Jan-2012, 11:43   #14
badgerpilot's Avatar
Purple.
You techy boys are ace, I press the red button and twist the grippy thing and it goes vroom till the fuel runs out or I crash.
Scott #50
Old 31-Jan-2012, 12:16   #15
Cranker V2's Avatar
Mood: Green with envy
Crash....................
Old 31-Jan-2012, 12:17   #16
ells ells is offline
ells's Avatar
Yep,
very interesting, but I am with Badger on this one (apart from the crashing bit)
Mark
Old 31-Jan-2012, 14:28   #17
Originally Posted by ells
Yep,
Mark
Thats because you both have carb'd bikes
When they start sucking in fuel is determined by when the inlet valve opens, and the amount of fuel sucked in is governed by the size of the jets and the vacuum above them hence why the airbox plays a part.
@ 10000rpm the engine only has 6mS for each 360 degree crank rotation, Cam duration is around 280 degrees on the injected bikes so only about 4.65mS to suck a fresh charge into the cylinder when flat out, yet injector opening times are often in excess of this, meaning fuel is being added while the valve is closed.
I may have to hook up the Oscilloscope one day and see how the injector pulse conpares to the pulse from the crank sensor and also to the Ignition timing
Old 31-Jan-2012, 14:41   #18
twist hard, go fast, simple as
from reading and listening to lots of this, the difference at the speeds we travel isn't huge. Yes there will always be a difference, as long as its 1 or 2 hp, and I lose no midrange, thats fine. When you start talking 180 hp, 1 or 2 for ours can be 10 or 20 - so worth the investment and time.
Aim is simple; good strong wide range, good fat torq and 63 hp flat balls out...and dont brake!
Old 31-Jan-2012, 16:49   #19
nogaromill998 nogaromill998 is offline
nogaromill998's Avatar
Well I've gone from twin front discs to none on my Class A bike this year.....I may add a set of rubber brake blocks if its REALLY needed to outbrake you Paul......Lol.....
Old 31-Jan-2012, 17:03   #20
wouldnt worry - I ran one disc no pads for lots of last season
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:03.
