Old 27-Mar-2012, 12:20   #11
Cobbett Cobbett is offline
Bikes: 750ss, 998s
Cobbett's Avatar
Originally Posted by fraggle
Is that a 50mm system all the way through?
Yes, 998S has 50mm system.
Old 28-Mar-2012, 07:44   #12
funkatronic funkatronic is offline
from my reading the 50mm headers with 50/54 midpipe and 54mm end cans is the best way to go as the full 54m system adds top end (9.5K rpm+) power at the expense of more usuable bottom end and mid range
also you will prob need to open up the air inlets in the nose fairing as this is a bottleneck. filter choice can make a big diference too.
forget a Power Commander (unless you have a very cheap one sitting round already), get your ecu repmapped by
BSD or CJS Racing
it will cost the same money and be better than a PCIII and dyno time anyway as more factors can be adjusted and at higher resolution than the PCIII
Old 28-Mar-2012, 11:49   #13
fraggle fraggle is offline
Mood: The 996r is back on the road!!!
Smile
BSD or CJS Racing
Thanks for the response, the 50mm headers with 50/54 midpipe and 54mm end cans is the way I would like to go. I already have the chip fitted which came with the 996r to support the 50mm Termignoni end-cans (and complete 50mm system), would this need to be changed?
Old 28-Mar-2012, 18:06   #14
Question
Originally Posted by pvw10
I believe 54's are more for the track and the payback in cost vs performance you would be wasting your time and money as a well sorted 50mm system is pretty hard to better.
I would though check you have the correct chip in in case you have the road exhaust one in ?
Does anyone know the number for the race chip?
Is there a quick way to check when fitted to the bike?
Old 28-Mar-2012, 20:58   #15
oh hang on the 996r has the 998 engine with modern ecu not chip so ignore the above and no, you have to pull the thing apart to check the ecu number.
New ecu number ?, Google is your friend.
Had a quick search on Google and found the following, anyone dispute this?
If it's any help, here are the numbers off the "stock" 996R ECU for the 50mm road exhaust, and the "race/open pipe" 996R ECU for the 50mm Termis.
The "stock" 996R road ECU has the following numbers on one side:
IAW59M 996R DUCATI007
On the other side:
S10DB104
The 996R "race/open pipe" (Termi) ECU has the following numbers on one side:
IAW 59M.A4
IAW 59M.A4/HW010/0115_115
12V= 129 01
OL +CVI95B
On the other side:
61600.655.00
996R
DUCATI007SA
Old 29-Mar-2012, 15:34   #16
have a 50/54 mm ecu here and the codes on it are
61600.630.00
996r
ducati007
ducati part code on the box is 96506801b
central 59mscarich d45 996r
cpu 59m exhaust d54 996r
dont know if the OEM 998s/996r 50mm ecu is the same or not as my 998s is not here at the moment
Old 29-Mar-2012, 15:36   #17
reading above post makes me wonder if i have the correct ecu in the box!
Old 29-Mar-2012, 21:23   #18
Bikes: 750ss, 998s
Cobbett's Avatar
Data I have on misc 998 ECUs (from my own notes) is:
96506801B = stock ECU for 996R/998S
96507502B = ECU for 996R/998S open / race 50mm Termis
96507402B = ECU for open / race 45mm Termis. Note the change of digit from 5 to 4: basically the variable around whether it’s for 45mm [stock] or 50mm [S] cans.
96507602B = Note that variable ‘6’ = ECU for 998R open / race cans
96507702B = hmm, dunno, ECU for 45mm to 50mm system?
Old 30-Mar-2012, 06:52   #19
I've just had a look at the ECU in the box with my standard endcans, I have not looked at the bike, so I assume this is the stock, non-race ECU, and the markings are as follows -
61600.630.00
996R
DUCATI 007
IAW 59M.A2
IAW 59M.A2/HW010/0115_099
12v 142 01
Old 30-Mar-2012, 09:45   #20
Bikes: 750ss, 998s
Cobbett's Avatar
61600.630.00
996R
DUCATI 007
IAW 59M.A2
12v 142 01
Correct, that is the stock ECU for 996R/998S, 50mm road cans, part no. as above = 96506801B.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:31.
