Old 19-Jul-2003, 09:26   #21
Dude Dude is offline
Dude's Avatar
Mood: Ducatiless, but got License back
Mr Sheene
Use Mr Sheene or other household polish to remove any oily marks on your wheel, exhuasts etc. Works a treat at removing it, seems to break it down and wipes off.
Old 20-Jul-2003, 22:02   #22
Originally posted by crm250
WD40 does clean the chain up nicely, but unfortunatley it dries out and perishes the rubber seals giving the chain an untimely death.
I've heard this before, but I'm still not convinced that it is the case.
I use WD40 all over the bike to clean rubber parts and I've never had one perish on me yet.
With the chain, you're cleaning it first with WD40, then reapplying the lube to ensure the o-rings remain in good condition. I'm sure that if WD40 did perish the rubber, it wouldn't have much of a chance in this short period of time.
Old 20-Jul-2003, 22:47   #23
Nigel Booker Nigel Booker is offline
Bikes: Ducati 996R and MV Agusta F4 1000R
Nigel Booker's Avatar
Tried PJ1 blue and chain kote teflon spray but eventually settled on castrol chain wax. Makes less of a mess and seems to stay on the chain longer than most. Covered about 12k on the original chain and haven't had to adjust it to often, should get about 16-18k from the original C&S set.
Old 21-Jul-2003, 08:47   #24
Guido's Avatar
R.E. WD40
I thought WD40 was petroleum based, hence it's abilty to remove grease etc.
If that's the case, I thought putting it on a chain would dilute/water down any wax spray you subsequently apply.
True???
Old 21-Jul-2003, 09:23   #25
Flanners Flanners is offline
Interesting debate on WD40 or GT85 etc. I've used these lubricant/cleaners on all my bikes for the last 12 years and never had problem with the chain, bodywork, plastics or hoses that I have used it on. In fact I swear by it. Would be interesting to clarify with the manufacturer.
Have emailed the manufacturer with our question and await the reply.
[Edited on 21-7-2003 by Flanners]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:56.
