Old 21-Jul-2005, 01:30   #21
Another popular leak is from either the o-ring that seals the cam bearing housing or the gasket behind the rocker pin cover plate.
You'll need to pull the battery tray off and then the cam belt cover.
Look for oil behind the cam pulleys.
Old 22-Jul-2005, 09:45   #22
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
Hi Rob,
Try this -
Fairing off, thoroughly degrease motor, and dry off completely
Liberally dust talcum powder (Johnsons baby is good) around the front cylinder and cases.
Take a ride.
With a bit of luck, you will be able to spot the origin of any oil leak.
Good luck
Old 22-Jul-2005, 14:04   #23
rob748b rob748b is offline
rob748b's Avatar
Mood: happy dayz!!
All sorted now,
thanks for all of your help and advice on this. Took it to get looked at and had a split pipe, also had a split coolent pipe so thats where the residue came from on the V Peice, so added together wasnt so bad I suppose but all sorted now, and i can get out riding worry free again!!
Thanks again Rob
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:23.
