Old 13-Nov-2005, 00:03   #21
ericthered40's Avatar
Mood: renegade sexy racer
Originally posted by ali
Originally posted by CK and AK
you will need a fuel injection pump Eric with the fuel injected engine, so unless you change the tank to the 'ie' tank, you will need an external fuel pump and a return to tank fuel line.
Talk to Paul Payne - he has already done this with an SS.
I have done it all with the monster.
You dont need to 'drill out' for larger engine bolts - you sleeve the engine - comes courtesy of B&Q for about £7 per length.
Means you can go back to 583 if you ever want to.
Note: if you are using any 620 engine with key recognition, you will need all the parts from that bike, unless you are using a different computer.
Hope this is of help?
Alan
The old SSs come with a fule pump as standard, but it's not as strong as the ie pump. The good news is that it's exactly the same size. The tank has a return spiggot on the bottom. Geoff reconned they just swapped the ie pump into the new tank and that was it, but I may be mistaken as the whole codeine/red wine thing is reaking havoc with my memory...
Ali
Plot thickening as we speak ?
I did wonder what the buzzing was when I turned the ignition on
[Edited on 13-11-2005 by ericthered40]
Old 13-Nov-2005, 00:11   #22
Can't see a problem with that junk low pressure (probably around 0.4Bar) pump inside tank and replace with a High pressure (probably around 3.0Bar) pump. Then its just a matter of finding somewhere to mount the pressure regulator
Old 13-Nov-2005, 17:16   #23
Nice one mate, looks very nice indeed!
Old 13-Nov-2005, 19:18   #24
Redruth Redruth is offline
Redruth's Avatar
Mood: Fabulous
Well done Eric. And everyone is being tremendously helpful, aren't they? Don't believe that red wine BS of Ali's though. His memory is goddam perfect. He may just be a tad reluctant to share is vast knowledge because he's worried about you being up his chuff next season
Old 13-Nov-2005, 19:21   #25
domski's Avatar
So would any man!!
Old 13-Nov-2005, 19:50   #26
Well just settled in after me first blast on the beast
So far i have discovered not to push a Sport max front tyre celebrating it's tenth birthday
It's actually much better than i had expected apart from the flat spot in between 2k and 10k it fly.
:P
Old 13-Nov-2005, 19:53   #27
ha!
Good on you Eric. She looks good too!
I've just gotten off the phone after having a chat about my bike for next year ... I'm really looking forward to this now
BRING IT ON NOW!!!!!!!!!
Old 13-Nov-2005, 19:55   #28
domski's Avatar
You realise the 'old' pilot struggled to stop it from crashing all the time - you sure you can handle it?
Old 13-Nov-2005, 19:56   #29
I might not be on that one now ...
Old 13-Nov-2005, 20:00   #30
Eat my dust Skippy
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:35.
