Old 18-Nov-2005, 18:56   #21
Paul748bp Paul748bp is offline
Paul748bp's Avatar
right the near side panal code is
480.1.042.1A
and the front nose is
481.1.012.1a
both have italian writing on them saying
ALIMONTE 35
hear also is my seat arrowed with the red bits showing
Old 18-Nov-2005, 18:56   #22
ducasa1 ducasa1 is offline
Its easy enough to add change of colour on log book (via DVLA). I have just looked at 2 redundant seat unit mono and biposto
First is a originally red (factory original) resprayed black and is showing white plastic where the termis have rubbed 3 mm gauges into the plastic.
Second a yellow mono is also showing white (not primer) where it is distressed. These are late panels 2002 and 2003 maybe in different panels or earlier models they were red plastic
I am not saying keefer is incorrect maybe they do make red plastic panels and respray them yellow but not in my experience
Old 18-Nov-2005, 19:00   #23
Maybe keefers is right, because I think a 1a is factory yellow.
But none of my yellow panels are showing any hint of red, maybe I need a lump hammer and chisel
Old 18-Nov-2005, 19:03   #24
keefer keefer is offline
keefer's Avatar
I would say that its original yellow. underneath certainly.
if you go back and look at the picture of the yellow 748SP I put up, all the broken parts reveal red all the way though the plastic especially on the top fairing.
perhaps now they do make them in a different colour.
I have been unfortunate enough to see quite a few broken panels and they have all been red all the way through
[Edited on 18-11-2005 by keefer]
Old 18-Nov-2005, 19:05   #25
Just looked at my mono, its worn on exactly the same place, but is showing clear plastic under white primer.
Im going to check on your part number
Old 18-Nov-2005, 19:16   #26
Clippy Clippy is offline
Bikes: 1098
Clippy's Avatar
Mood: Enjoying a REAL summer!
I bought a 748BP new from OYB in 1999 and it wore through red in exactly the same place under the seat unit...
...in fact, you may have my old bike...
Reg No doesn't start S611 does it?
Giles
Old 18-Nov-2005, 19:21   #27
Paul need the seat number
From the evidence so far, I conclude that Ducati used to re spray red panels yellow (cheapskates) but not on the later bikes, well not on my yellow 998s panels anyway.
Or maybe they did it at the end of production runs (as quoted by a Ducati dealer to me), remember they were often cash strapped and used to cobble bikes together.
And Paul you are probably none the wiser. If you find out more from this saga let me know because I’m confused now
Old 18-Nov-2005, 19:34   #28
Paul748bp's Avatar
i cant seem to find the number on the seat ???????
and my reg is S407
sorry
the panels all look ducati done it would seem odd that the previous owner would spend X amount on respraying the whole bike and have to get the tank done it would be more to just get new panels
Old 18-Nov-2005, 19:42   #29
Your nose cone is 1A which is a factory unpainted should be a BB for yellow.
From what I can see Ducati only supplied a unpainted seat for the 748 Bi posto in that year (should end in 3A), so I think all your panels are factory unpainted.
Old 18-Nov-2005, 19:51   #30
It's very normal. Don't worry about it. The panels are moulded with a red "resin". The paint is then applied to finish the panel.
Even black ones are red underneath..............
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:10.
