Old 25-Jan-2006, 17:57   #31
Originally posted by paynep
Five cylinders??
Ant, did you use a spacer through the engine cases or drill and re-tap the frame for the larger 620 engine mounting bolts?
I've used the std rear top bolt with the casing sleeved (£2.99 from Homebase!) but can't make my mind up how to do the front as I may want to be able to put a 583 motor back in at some stage....
Did you have any clearance problems with the ECU/battery under the tank or are you relocating it all for better weight distribution?
Cheers, Paul
Both front and back mounting points on the engine were sleeved to save modifying the frame for exactly the same reason as you. Mark brought along a collection of oem engine bolts and we found that the 900 bolt was fine for the front - I can measure it if you want as they were all about 5 to 10mm different in length.
As for the battery, we didn't try the tank but just fitted all the airbox in place which works fine. It sits lower than the 583 engine one, by about an inch, so I don't think it will have clearance problems... at least I hope not! I'm sure it wouldn't take much to go to a Monster tank or relocate things if it did.
The only other thing you need to do is sort the fuel pump for the FI, and this we did by using a fuel pump from a Trumpet. They are exactly the same dimensions as the oem one for the 583 and put out the same PSI as the oem Ducati FI pump. You can splice the Trumpet connector into the Ducati harness and all the pipes are the same size, so it fits right in place of the Ducati one. We picked a couple up off ebay for less than 15 quid each. Like this one:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=8032657955
I've got my camera here, so I'll post a couple of pics of the frame once I've resized them.
Old 25-Jan-2006, 18:00   #32
Originally posted by AK and CK
so is the engine up & running Antony?
Nope, just fitted it to the frame to check the frame wouldn't need chopping before sending it away for powder coating.
Once it's back we'll fully fit the engine and get it running, but I'm sure it will be fine
Old 25-Jan-2006, 18:47   #33
Here's the 620 engine in the 583 frame. You can see that there's enough room to clear the cross brace at the front, but it fits!
Old 25-Jan-2006, 21:55   #34
paynep's Avatar
Mood: Wet wet wet
Thanks Antony, I was wondering about the 900 bolt myself.
I sorted my pump by buying a complete tank, removing all the internals and flogging the bare tank to break even! Although I fully expect the tank to finish ahead of its internals..........
Old 25-Jan-2006, 22:01   #35
domski's Avatar
Attachment: frame_620.JPG (229.88kb)
Looks great Ant - your bike is finished!!
Reckon the weight saving will be worth 5 seconds a lap
Old 25-Jan-2006, 22:07   #36
ali ali is offline
ali's Avatar
Mood: Damp
I expect it'll finish ahead of the rest of the bike as well!
Old 26-Jan-2006, 01:28   #37
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
That seems to fit ok, But I see you are on active fit
Old 26-Jan-2006, 01:57   #38
Those are for the "Oh *****" moments when Dom comes pogo-ing past...
Old 26-Jan-2006, 03:00   #39
domski's Avatar
Those are for the "Oh <b>censored</b> " moments when Dom comes pogo-ing past...
Don't tell him that FFS
That's supposed to be our little secret!!
Old 26-Jan-2006, 17:53   #40
fil2 fil2 is offline
fil2's Avatar
Mood: is it still wet
620 lump in a 600ss frame......i would like that....................
best of both worlds............
hope it works out for Ant..........
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:00.
