Old 06-Feb-2006, 23:34   #71
Originally posted by antonye
You still need to get those cone nuts off the ignition?
Get the right sized bolt to fit into the thread of the cone nut, about 40mm long or so will do, then wind a nut onto it.
Now wind the nut and bolt into the threaded cone so you've got lots of thread in there, then wind the nut up to the cone and tighten it right up.
Now you can start to undo the bolt and it should undo the cone nut. If not, tighten up the nut some more and try again.
Finally hold the bolt and slacken the nut, then you can spin off the cone nut.
HTH.
Have you taken something?
Old 07-Feb-2006, 11:01   #72
Yes
Old 07-Feb-2006, 17:21   #73
chillo chillo is offline
chillo's Avatar
Andy,
have you cut your fairing so it fits the 04/05 swingarm?
also need to mod the link pipe??
looking good
Old 07-Feb-2006, 18:45   #74
butch890 butch890 is offline
Mood: Enjoying Togdom !
Originally posted by chillo
Andy,
looking good
The original pipe will clear the new swingarm,(you wouldnt believe the size of the dent that sledgehammer made!)
And yes Andy they did say how special your frame is - NOW!
Butch
Old 07-Feb-2006, 19:40   #75
Andy,
looking good
Yeah all that to come.........
Old 09-Feb-2006, 20:27   #76
ooh, ooh, ooh, my frames ready!!
Old 10-Feb-2006, 02:22   #77
chillo's Avatar
Originally posted by Carbon749
Originally posted by andyb
off to jhp tomorrow................
After listening to other tales of woe on here, make sure the frame number is well masked before it's blasted and powder coated
whats the tales of woe for not masking your engine number?? it will still be there underneath
Old 10-Feb-2006, 17:01   #78
mine was masked!:D................and i hope the shot blasting prior to powder coating removed the rust around the headstock as well!
Not bad for a £20000 bike...........
Old 10-Feb-2006, 17:04   #79
I didn't mask mine when I had it powder coated, although I didn't have it shot blasted. The powder coat has made the frame number less obvious, but you can still see it.
Old 11-Feb-2006, 20:19   #80
The frames back.......
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:31.
