Old 12-May-2012, 18:10   #1
bally71's Avatar
Mood: Inquisitive cat
go Keyless
Guys
Getting rid of the ignition barrel and replacing it with a toggle switch
so which wires do what then??
Iv'e got a:
green / black
red
yellow
grey
red/white
blue
Any ideas on what's the best way to wire it up
Old 12-May-2012, 20:56   #2
Red & Green/Black on Switch side
Red/Yellow & Red/White Harness side
Old 12-May-2012, 21:17   #3
bally71's Avatar
Cheers kev .. blimey mate you really do have all the answers
what do you mean by switch side / harness side
Thanks again your a star : )
Old 12-May-2012, 21:19   #4
bally71's Avatar
And can i just cut the others?
Old 12-May-2012, 21:31   #5
The cable from the ignition switch goes down to a 6-way connector usually just behind the head stock, so one side of the 6-way connector is on the end of the ignition switch (switch side), the mating connector is on the main harness (Harness side)
The other wires are for parking lights when the steering lock part of the ignition switch is fully to the left, so those wires aren't required.
If you have original clocks (with flashing amber LED) and ECU fitted then you will probably need to salvage the transponder from the key (or keep the key) and mount it in the aeriel that is mounted in the housing around the ignition switch and tuck the lot away under the tank.
Either that or get the clocks decoded. I've just spent the last few hours going through Coded Clocks and ECUs on my M620, playing match up.
As my race bike and the M620 are about to be fitted with Decoded ECUs that I have just done
Old 12-May-2012, 23:42   #6
bally71's Avatar
Ecu is decoded so no worries there
muchos gracias
hopefully have it finished soon so i can get out on the track and bother you there instead lol
Old 13-May-2012, 21:29   #7
Spjallen Spjallen is offline
I'd like to do this mod too, but haven't got the bottle. See how yours works out first!!
Old 14-May-2012, 08:26   #8
bally71's Avatar
Lol ok .. i know .. electrics .. scary
cutting the loom down is next job .. then i'll be pooing my pants
Old 09-Jun-2012, 19:29   #9
Have you gone keyless yet!??
Old 09-Jun-2012, 22:07   #10
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
There's 1 wire that's not obvious when you cut the loom down so be careful.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:52.
