Old 10-Mar-2005, 12:03   #1
Frank Frank is offline
Mood: got to be a worry.....!
rear sprocket cover
this may not be explained too well but...
One of the 5 nuts rotates (with the use of the socket so we are not talking loose) with the thread ie the nut does not come undone but neither can it be tightened up fully,
any ideas if this is ok, normal?
Old 10-Mar-2005, 12:08   #2
Is that one of the cush drive nuts?
Old 10-Mar-2005, 12:12   #3
I think so.
Old 10-Mar-2005, 12:19   #4
I wouldn't say it's normal then, but I doubt it would cause you any major problems for now, check your eccentric hub though to make sure it isn't or hasn't backed up and has started wearing the adjustment out.
Nelly will probably clarify this...
Old 10-Mar-2005, 17:02   #5
smilo006 smilo006 is offline
smilo006's Avatar
Mood: I like my bike
When taking the cush drive nuts off you need to put a large hex key behind the cush drive to keep it still. Whether this means that the cush drive is worn or not I do not know.
It was a while ago I did it. As I recall you need to be careful of the swing arm and ensure the key does not grate on it.
Old 10-Mar-2005, 18:29   #6
adam adam is offline
Mood: happy
easier to remove the sprocket then tighten. Gives you the chance to clean around that area with the sprocket and chain out of the way.
Old 10-Mar-2005, 18:33   #7
Hey Adam, well done mate! i see youve taught that carrier to come off on its own now!!
What next ..Sit!!
Old 10-Mar-2005, 18:49   #8
Mood: happy
did i say its easier to remove the sprocket, oh yeah, well it is when you try.
very long scaffold pole.
andy, my next trick it to remove the bolts holding the clutch basket in place whilst having no chain on and no holding tools.
Old 10-Mar-2005, 18:50   #9
Dont start asking clutch questions..
Old 10-Mar-2005, 18:51   #10
Simple- Air gun!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:43.
