Old 29-Mar-2005, 19:55   #1
doogalman's Avatar
Favorite mod???
Just pondering what people rate as the best modification they have made to their bikes, albeit performance or cosmetic.
I think mine has to be loosing indicators and mirrors , it makes the bike look leaner and more focused.
Well what are your favorites????
Doogalman
Old 29-Mar-2005, 20:00   #2
adam adam is offline
Mood: happy
Íve made a few, slipper clutch (JHP) Brembo brake/clutch master cylinders, PFM brake set up. All very nice. Favourite one, PFM brakes.
Old 29-Mar-2005, 20:30   #3
Mood: Diet
suspension setup
slipper clutch
Old 29-Mar-2005, 20:35   #4
Walenut Walenut is offline
Mood: Erratic
Pipes let her sing
Old 29-Mar-2005, 21:04   #5
Mike Davis Mike Davis is offline
Mood: Shiney
powercommander, sorted out all fuelling problems and the bike is an absolute joy to ride.
Couldnt`believe the difference after several different chips and having the co set up, still leaving small glitches it was a stark contrast.
Old 29-Mar-2005, 21:12   #6
ath748 ath748 is offline
ath748's Avatar
Mood: Missing my Flash...
Termi's to get that real Duc feeling for me
Old 29-Mar-2005, 23:09   #7
Pete A Pete A is offline
Pete A's Avatar
Of all the mods. and I've done loads, (with plenty more in the pipe-line!) it has to be the 50mm titanium Termi's. - The best bit was having had the bike serviced at John Hackett's, when they fired it up I expected the mechanic to say "you should hear what they sound like with a full 58mm system", instead he shook his head and said "f*** that's loud!" I don't know if it's because they're really tightly packed, or the titanium sleeves but the sound is quite vicious, still has to be the number 1 mod.!
Old 30-Mar-2005, 11:06   #8
Mr_S Mr_S is offline
In order of smiles / pound on my little 748...
Magnesium wheel
Slipper Clutch
Suspension (Fork rebuild / springs / revalve, Ohlins rear Matris Steering Damper)
SPS Conversion (Heads, pistons, cams, cam timing, Dyno setup etc)
The next mod's I make will most likely be to my riding by re-visiting CSS etc.
Jason
Old 31-Mar-2005, 00:02   #9
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
In order,
I would say that the 748 to 853 conversion.
The next one would have to be the front brakes being uprated to Brembo P4 monoblocks with a radial master cylinder.
Finally, having the forks revalved and rear shock replaced by ohlins. took some time setting up with much head scratching but im getting there and well worth it.
DC.
Old 31-Mar-2005, 00:05   #10
ziggi ziggi is offline
ziggi's Avatar
Oh my italian flag rear reflector Coutesy of RipSnortingVtwins
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:48.
