Old 31-Mar-2005, 19:13   #1
Ericsson Ericsson is offline
Difference pistons 748R vs 748RS
Anyone know the difference, if any, between 748R and 748RS pistons ?
Higher compression? Could there be a clearance problem with 748R heads and cams?
Cheers,
/Uffe
Old 31-Mar-2005, 23:55   #2
Mr_S Mr_S is offline
They're exactly the same, as required by the supersport homologation rules, so no increase in compression.
Valve lift is also the same on the R and RS.
RS's run (up top) different cams (shorter duration, to close faster ) and different valves (same size different material) RS ports are fully open to 36mm where R's are still around 33mm (easy gains for an R...)
[Edited on 31-3-2005 by Mr_S]
Old 01-Apr-2005, 17:58   #3
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Wouldnt happen to be bidding on a certain pair on ebay by any chance would you Uffe ??!
Nat
Old 02-Apr-2005, 20:24   #4
Thanks Mr_S, as always informative answers :thumbsup
Natty: Yes, I was keeping an eye on those, but it wasn't worth it for me in the end with shipping from UK. I only need one piston and already got a bunch of cylinders. Someone else was lucky this time.
Now I'm just waiting for a mint horiz. 748R intake cam ;-)
I've got a pair of new unused 0E marked intake cams which I don't need, anyone care to swap?
[Edited on 2-4-2005 by Ericsson]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:17.
