Old 03-Apr-2005, 20:55   #1
deej deej is offline
deej's Avatar
whats this leak
and how do i stop it ???
i have noticed a oily like fluid leaking from the part in the photo, how can i fix this and what damage have may i have caused by riding it like this ???
Old 03-Apr-2005, 21:05   #2
Lily Lily is offline
Mood: stiff and tired
Looks like your oil breather.... replace it maybe???
Old 03-Apr-2005, 21:19   #3
deej's Avatar
cheers lily
anyone else help ???
rough price ??
Old 03-Apr-2005, 21:20   #4
no idea about price, but you can get 'bling' ones from jhp etc
not really mu cuppa, but they can look ok on the right bike.
Old 03-Apr-2005, 21:22   #5
keefer keefer is offline
keefer's Avatar
http://www.ducatisportingclub.com/xm....php?tid=18058
for a comprehensive look at this problem,
reed this from earlier today
Old 03-Apr-2005, 22:14   #6
deej's Avatar
whhoah
shazaam goes into such detail im now confused,im not technically minded ( yet ) so im guessing i need a new cranckcase breather because im riding the engine too hard and too fast which sounds about right
how much was yours keefer and have you got any pictures please mate
Old 04-Apr-2005, 00:24   #7
keefer's Avatar
should be all finished by the end of this week, will post pics then.
its not the cheep option though,
probably best to go for the hollowed out breather with reed valve in air box option.
have a look at Shaz's post again
Old 04-Apr-2005, 00:25   #8
Harv748 Harv748 is offline
Harv748's Avatar
Its not a big deal Deej...you'll find a lot of the older 748/9** models with the same thing. I notice yours still has the old type of breather (with the silver metal surround/edge). The newer types appear to be all plastic.
I think these are slightly better, and also come with some form of 'o' ring or gasket to try and avoid this small leak. You will also see a lot of bikes with silicone around this breather in a bid to stop it as it is so common.
Talk to Nelly, I'm sure he can sort you one out, and talk you through the removal/refitting.
Old 04-Apr-2005, 02:00   #9
Most of the older ones leak. They use an alloy washer as a gasket. Simple cure is to take off the breather, coat the washer in threebond, refit and tighten down. Solves the problem 9 times out of 10.
Old 04-Apr-2005, 12:26   #10
rcgbob44's Avatar
Why not just clean it by flushing it out?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:52.
