Old 10-May-2005, 14:59   #1
jj250 jj250 is offline
jj250's Avatar
Help !! its only running on one!
Had my 748 serviced last week(major), bike went in with no Known problems,picked it up thursday and went out last night for the 1st time,every thing spot on for 30 miles then it begins to run on one cylinder and then back to two, as soon as you slow down its back on one, any ideas?
Old 10-May-2005, 15:12   #2
Got to be electrical, have you checked plugs, HT leads, connections, "coils" etc, etc.
What's the age/mileage of your 748? If it isn't any of those do you hear any unusual noises? a clunking/knocking noise? do you know, can you tell if the l/h engine casing has been removed when serviced? you should be able to see new threebond (SP???) on the casing/seal etc, the reason I say this is that the alternator nut may be loose which can cause a similar problem, it should be re-torqued every 12,000 miles I believe, but the casing needs to come off to get to it.
Old 10-May-2005, 16:15   #3
Brent Brent is offline
Brent's Avatar
My 748 turned into a single at the weekend. On idle or closed throttle, it went onto one. Plugs looked OK but cleaning them only made things a bit better so I renewed them, and now it seems fine.
If it's just had a major service I assume they changed the plugs though (and tightened them up OK).
Old 11-May-2005, 14:49   #4
jj250's Avatar
The casing was removed to have the alternator nut tightened,the rear plug lead was replaced with a used one for some reason which leads me to think that it will be the cause,ive ordered one today so fingers crossed
Old 11-May-2005, 14:55   #5
The rear lead was replaced with a used one? Hello..... !!!! and you're buying a new one???? Am I missing something here?
Old 11-May-2005, 14:55   #6
moto748 moto748 is offline
Originally posted by jj250
...the rear plug lead was replaced with a used one for some reason...
Shurely you shouldn't have to fix that at your own expense?
Old 11-May-2005, 15:00   #7
jj250's Avatar
Guys, after paying out £700 and having the bike play up within 30 miles im feeling pretty loathed to take the bike back, also the company in question suggested i ride it down to him, (more time without the bike!) and they will change the fuel potentiometer?? and i can try that!! Lets say im losing confidence fast.....(what really irks me is the fact that i paid to have injectors cleaned and £80 more in labour to solve a problem that wasnt there when i dropped the bike off,but is happening now!!)
[Edited on 11-5-2005 by jj250]
Old 11-May-2005, 15:03   #8
So who/where did your service?
Give us a clue at least, which county?
Old 11-May-2005, 15:05   #9
jj250's Avatar
Nr bristol......and its not riders
Old 14-May-2005, 11:12   #10
yorkshire pud yorkshire pud is offline
Mood: poon tang
you got ripped:mad :
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:47.
