Old 16-May-2005, 09:30   #1
mikecardiff mikecardiff is offline
Anyone fitted Raask bar risers ?
Looking on the busters site saw these : http://www.busters-accessories.co.uk...l.asp?prod=RAA
Has anyone fitted them or tried them ? was thinking of getting the Helibars, but only really need to get the bars higher, so what do you reckon to usign these ?
As far as I remember Raask stuff is pretty good quality and they are a lot cheaper than the helibars !
Old 16-May-2005, 10:31   #2
the phantom pieman the phantom pieman is offline
the phantom pieman's Avatar
Mood: Sort of shuffling along .....
Try Cycle Cat raisers from Spareshack ...
Will give about 1.5 inches of rise at the max . And then also adjustable
Old 16-May-2005, 10:40   #3
Yeah, I looked at the cyclecat ones, problem is you need to adapt the clutch and brake cylinder connections to fit, so thought it would be simpler using some where I can keep the original ones ( like the Heli bar ones ) - the cycle cat also cost LOADS more than the Raask
Old 17-May-2005, 01:21   #4
HANCYM HANCYM is offline
Correction mikecardiff!!
Fitted the Cycle Cat ones to my 748 last month and they go straight on WITHOUT and mods to the brake and clutch connections. They are so adjustable you can easliy accomodate the original stuff. The only things you need to replace are the two pieces of hose from the two fluid pots and their mounting brackets, all included.
Old 17-May-2005, 08:16   #5
m1keyp m1keyp is offline
Fitting the cyclecat bars is easy, I did it!!!
They are probably the best modification I have made
Old 17-May-2005, 09:08   #6
Hmmm - got me thinking now - I might get the Raask ones first as they are only £40 and see how they feel, can always get the cycle cats later on - generally I dont mind the position of the bars, they could just do with being a bit higher to take some of the weight off in town.
Old 18-May-2005, 07:55   #7
crm250 crm250 is offline
crm250's Avatar
Mood: Firing on all 4 !!
did my cyclecat ones yesterday, quite easy to fit, only needed to trim the locator out of the kil switch. they are wider and certainly flatter and come out level with the top yolk without any clearance issues. the 2 feed hoses did need replacing with the ones supplied but that was all.
Old 18-May-2005, 09:38   #8
Have ordered a set of the Raask risers - only £35 so worth giving a try just to see what they are like at that price.
Will get some pics done once they arrive and I fit them so people can compare them to the Helibars and Cyclecat and see the differences.
Old 23-May-2005, 11:11   #9
MrWestys748 MrWestys748 is offline
What size did you order, was it 43mm...?
Old 23-May-2005, 19:05   #10
Ermm I think so ( hope so as the 748 does have 43mm forks ??? )
Why ? you've got me worried now !
Mike
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:18.
