Old 04-Jul-2005, 08:59   #1
Rick Rick is offline
996 S 2001
Hi, does every 2001 model of the 996 S have the SPS motor in ?
I cant find a 996 SPS in my budget so maybe I can have at least the motor
Old 04-Jul-2005, 09:48   #2
yeti yeti is offline
yeti's Avatar
A 2001 S should have the SPS motor, but you would need someone like John Hackett to check engine numbers against the Ducati build log to confirm.
However, don't think you are getting a full blown SPS motor, cos you're not. As far as I can remember you only really get the bottom end, Ti rods etc. Fairly certain top end is pretty standard bip with regard to cams etc.
Old 04-Jul-2005, 10:13   #3
ziggi ziggi is offline
ziggi's Avatar
I thought the S engine was the same except the expensive Ti rods and lightened flywheel. Some S models did get SPS engines directly on the production line as they were left over, so to speak.
Old 04-Jul-2005, 11:39   #4
smilo006 smilo006 is offline
smilo006's Avatar
Mood: I like my bike
As I recall Duc said that there were no Ti rods. However on closer inspection there were. The power delivery (mapping) was changed to provide a smoother and more relaxed delivery. Should be possible to sort, if the cams were not changed as well.
Old 04-Jul-2005, 16:09   #5
ziggi's Avatar
The 996S also had the same cam shaft as 996SPS with the ability to change the "profile" if that's the right word.
Old 04-Jul-2005, 23:51   #6
Thanks guys
Old 12-Jul-2005, 22:53   #7
Webcore Webcore is offline
996S engine = 996SPS engine
Ducati parts catalague cross referenced
Only difference is the flywheel and the injectors as far as I can tell.
Old 14-Jul-2005, 08:52   #8
Bungi Bungi is offline
i may be wrong,
but it was my understanding that the 996s engine was pretty much the 916 sps engine and that the 996sps was a differant thing altogether
Old 14-Jul-2005, 10:00   #9
ziggi's Avatar
no - it was the 996SPS engine and was "supposed" to be without the Ti con rods and lightened flywheel.
Old 16-Jul-2005, 14:19   #10
That's why the 996S was such a bargain (relatively speaking) - But the US version just had a standard Bip engine.
Ziggi - is that a mag swing arm on your 996?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:03.
