Old 02-Aug-2005, 14:23   #1
bossingit bossingit is offline
bossingit's Avatar
Mood: suns out...happpy!!!brm brm
open clutch cover...bit ignorant
about fitting one on my 996....can i just bolt it straight on or are there any other mods i need to make,also,apart from the extra noise...what advantages do they hold?
Old 02-Aug-2005, 14:24   #2
dickieducati's Avatar
get rid of all the clutch dust
Old 02-Aug-2005, 14:35   #3
bossingit's Avatar
so no other mods needed then,just bolt it straight on?
Old 02-Aug-2005, 14:44   #4
yes just bolt on. simple. not sure if they have a cooling effect too, probably. the only things to consider are how strong it is in the event of an off and also be careful when cleaning that you dont pour loads of water in there.
Old 02-Aug-2005, 14:46   #5
748IOM 748IOM is offline
Mood: Yellow!!
It is simply a cover for the clutch to protect the moving parts from damage, so no mods are really required although many replace the springs and bolts within the clutch for stainless type to prevent rusting, I would recommend doing this anyway.
The vented clutch cover releases both the dust build up and that wonderful dry clutch sound (in other words the volume of the rattly clutch will be increased).
Old 02-Aug-2005, 14:50   #6
bossingit's Avatar
ok gents,best i go and buy one then!!!!
Old 02-Aug-2005, 14:59   #7
Mood: Yellow!!
I would, just remember that they don't offer the same protection from the elements than sealed versions and so I'd be more inclined to limit their use to dry rides.
Old 02-Aug-2005, 15:23   #8
m1keyp m1keyp is offline
Get a strong one, not carbon
These are great http://secure.speedymoto.com/Merchan...gory_Co de=CC
Old 02-Aug-2005, 15:26   #9
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
And if you speak nicely to Nelly, he'll sell you one!
Old 02-Aug-2005, 16:23   #10
Mine came from nelly with a 48 tooth basket
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:45.
