Old 28-Aug-2005, 20:06   #1
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
748 standard air filters
Hi,
I need to know if the standard foam type air filters that sit in the air runners on my 748 can be serviced?
The Haynes manual states that they should just be replaced. I would rather clean and re use but..........................what is the general opinion here amoungst owners? And if they can be cleaned, what does every body use?
Ta,
DC
Old 28-Aug-2005, 20:45   #2
ath748 ath748 is offline
ath748's Avatar
Mood: Missing my Flash...
For the price I just replace them.... Aren't they only about £20 or so...
Old 28-Aug-2005, 22:39   #3
aka.eric aka.eric is offline
Pipercross - direct replacement around £20.Much better than standard.
Old 29-Aug-2005, 01:15   #4
Short Answer:
http://ducatisportingclub.com/xmb/vi...age=#pid148737
Long Answer:
http://ducatisportingclub.com/xmb/vi...=1701#pid12578
Old 30-Aug-2005, 13:20   #5
Craig G Craig G is offline
Mood: Fed up
Without the airtubes and filters in place, so the air intake is exposed would the bike still run, or just cough, splutter and die?
Old 30-Aug-2005, 13:57   #6
gary-g gary-g is offline
Bikes: Sts4s in red, of course!
gary-g's Avatar
Mood: Ah....Switzerland!
remove the mesh, restrictors inside the air tubes, std filters and throw them away.
replace with an ITG filter inside the airbox.
marvel at the improvement
Gaz
Old 30-Aug-2005, 14:25   #7
ziggi ziggi is offline
ziggi's Avatar
Make sure you read Shazzams posts carefully to obtain the optimum conditions for 748/916 models and why.
Basically it's:
Airtubes (yes, you need airtubes to get air effectively into the airbox)
Pipercross standard type filters in the airtubes (improved airbox resonance)
No aftermarket in-airbox filter (as this reduces the airbox capacity)
Old 30-Aug-2005, 14:48   #8
phil_h phil_h is offline
phil_h's Avatar
The big reason to replace the std ones is that they let crap through into the airbox
What you want is a big washable foam hat over the inlet trumpets
All the other advice is pants if you get leaves and crap down your trumpets
(Or is that leaves and trumpets down your pants )
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:01.
