General Motorcycles only
Old 03-Oct-2005, 23:07   #1
whyworry whyworry is offline
Mood: ;)
Rusty petrol tank -inside
can any clever clogs tell me how to remove rust from inside a classic bike petrol tank?
i have some of the stuff you can buy which coats the inside when you eventually do get it all clean inside- but is it any good? and whats best way of getting it clean and rust/muck free??
Old 03-Oct-2005, 23:21   #2
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
In the olden days we used to put a couple of handfulls of stone chippings in and shake like bu**ery til your arms dropped off.
Cleans your tank and gives you arms like a gorrilla
Old 03-Oct-2005, 23:22   #3
monstermob 998's Avatar
i havent tried this myself but it was featured in classic mechanics- as well as a tip of placing ball bearings in the tank and shake to remove loose rust( dont know wether i would try the ball bearings myself)
http://www.frost.co.uk/result_search.asp
i think the kit is just a rust inhibitor and coating of zinc phosphate
[Edited on 3-10-2005 by monstermob 998]
Old 03-Oct-2005, 23:29   #4
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
I had this on a Landrover some years ago.
I used the ball bearing idea to knock off the flaky stuff then used some resin to line the tank - can't for the life of me remember the name of it but it's regularly advertised in Classic Bike & Classic car mags.
To my knowledge, the tank which had the consistency of lace in places when I started out, was still totally petrol tight 5 years later after being abused off road and generally mistreated.
Old 03-Oct-2005, 23:33   #5
Petseal might it have been?
Old 03-Oct-2005, 23:35   #6
Rushjob's Avatar
Mood: :-)
Give that man a cigar!
Yes... that was the stuff!
Here...... Petseal
Old 03-Oct-2005, 23:37   #7
my mate just suggested sand blasting with a pressure washer he says tthat he thinks karcher does them???????
just done a quick seerch and found this
http://www.justoffbase.co.uk/s.nl/sc.9/category.373/.f
may help
Old 04-Oct-2005, 09:55   #8
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
POR 15 Motorcycle Tank Repair kit is what you need.
http://www.frost.co.uk/item_Detail.asp?productID=8222
I used it on my '95 900SS whith excellent results. It includes a metal cleaner, rust convertor which gives a Zinc oxide coating and finally a flexible coating which lines the entire tank. This stuff is good !
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:24.
