Old 10-Oct-2005, 20:11   #1
rob holmes rob holmes is offline
bike won\'t start
Just tried starting my 748 and it just turned over without starting then just made a kind of fizzing noise from the relays at the side of the battery. Is this a faulty relay? or something more serious? any help would be gratefully received.
Old 10-Oct-2005, 20:16   #2
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Hi Rob
May be the starter solenoid jobby which accumalates cack and eventually causes a weak connection..assuming you know where its is, dismantle it, clean it up, crimp the connectors and reassemble (securing with a zip tie) and try again..
Good luck
Nat
Old 10-Oct-2005, 20:24   #3
Hi Nat
Don't suppose you know wherabouts it is do you? Know jacksh-t about electrics!!
Old 10-Oct-2005, 21:11   #4
Nattyboy's Avatar
On the rigt handside..in front of the battery...just following the terminals back from the battery and it will lead you to it mate..you might even find it starts if you wigle it about..!
Nat
Old 10-Oct-2005, 21:43   #5
Hurrah it starts, thanks for that Nat nice one. me thinks i will be getting pretty familiar with electrics on the duke over the coming months!!!
Old 10-Oct-2005, 22:03   #6
Nattyboy's Avatar
Great !! Just make sure you clean it up proper and zip tie it up..shoudlnt give yopu any more grief then..
Does that mean I get a virtual pint of stella...??
Nat
[Edited on 10-10-2005 by Nattyboy]
Old 10-Oct-2005, 23:09   #7
one virtual pint of stella coming up!!!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:57.
