Old 02-Nov-2005, 21:13   #1
phil911 phil911 is offline
phil911's Avatar
Mood: Privileged ...
Nice racing footpegs carbon ...
Have a look !!!
http://cgi.ebay.com/ebaymotors/DUCAT...8 18105QQrdZ1
Old 03-Nov-2005, 14:24   #2
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
Would anyone know if these would fit an 89 851?
Help would be appreciated
Old 03-Nov-2005, 14:57   #3
They are almost identical to the ones I have fitted to my 998 ...
Tasty
Old 03-Nov-2005, 15:12   #4
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
You'll also need to find the matching brake pedal and live with a race pattern gear change!
Old 03-Nov-2005, 15:24   #5
Weren't Sandbar looking at making racing rearsets from the original moulds? I wonder if that included pedals?
Why would you need a race pattern gear change Rob? Surely a different length linkage would do the trick?
Mind you, I've been thinking about trying race pattern myself just to see if I like it
Old 03-Nov-2005, 15:42   #6
yellow916 yellow916 is offline
Phil
Pretty sure they won't fit the bikes with the early frame (the one with the plates to which the footrest assemby is attached, rather than lugs). As Jools said, not sure why you would have to go for a race-pattern change, but I agree you might have to experiment with linkages etc. I actually tried a race parrten shift for a while, but went back to normal eventually. It wasn't the pattern itself that was a problem - you soon get used to that, except when you have a lapse in concentration - I just didn't like it. It felt all wrong, especially when accelerating hard. Mind you, quite a few racers use it, so it's probably just me! I think I've still got a lever (actually from a 9xx) if anyone wants to try it.
Andrew
Old 03-Nov-2005, 16:04   #7
Rob B's Avatar
Jools, The carbon hanger plates on the Corse, similar to pic, have no provision for a gear change lever. The race bikes had a lever directly attached to the splines on the gearbox, thus the reversed pattern.
Rgds, Rob
Old 03-Nov-2005, 18:45   #8
philthy's Avatar
Thanks for the advice gents. Looks like it could have been one of those '' good idea at the time '' mistakes which end up at the back of the shed and haunt you every time you look at them and remember how much they cost
Old 09-Nov-2005, 08:52   #9
NUx NUx is offline
NUx's Avatar
They went off for $611.95.
I little bit to much for me, but I guess the new owner will be happy.
New ones cost a lot more
[Edited on 9-11-2005 by NUx]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:43.
