Old 08-Nov-2005, 17:46   #1
m1keyp m1keyp is offline
Machined Clutch Casing
The machined open clutch casing (casing not clutch cover) on the corse bikes look great and expensive
Please can someone tell me if it is possible to get the standard item machined? If so is it expensive
Is there any downside to fitting this to a road bike?
Old 08-Nov-2005, 17:49   #2
butch890 butch890 is offline
Mood: Enjoying Togdom !
both my 890 and baby R have machined primary casings,not sure of total cost because both were done during full rebuilds,i think the machining costs were about £80 ish
Butch
Old 08-Nov-2005, 17:50   #3
Contact Neil748R; he's done it for his own bike and a couple of others and is very happy with it. He's a perfectionist so it must look good!
Old 08-Nov-2005, 21:18   #4
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Downside is a lot more crud to get into the clutch
Old 08-Nov-2005, 21:41   #5
keefer keefer is offline
keefer's Avatar
upside is a lot more dust can get out :P
Old 08-Nov-2005, 21:59   #6
Stealth Stealth is offline
Bikes: 998R, Panigale S
Stealth's Avatar
JHP used to do an exchange. I remember paying £60 some two years ago.
As to crud... well I guess you let crud out (have you seen the inside of closed cover?) as well as risk crud in. However, I ran a 996 for over 20K miles with a machined casing and had no problems. It is arguable whether it is worse than a vented clutch cover. I am not sure it matters. It looks good and will ventilate the clutch better.
Old 08-Nov-2005, 23:39   #7
Carbon749's Avatar
Mood: I own a flame thrower
I was thinking of doing this over the winter to my 749.
Anyone got a decent pic of a machined casing ?
Old 08-Nov-2005, 23:41   #8
Jon Jon is offline
Jon's Avatar
True, but lets say you hit the gravel trap
Old 09-Nov-2005, 12:03   #9
keefer's Avatar
there are lots of what if's on track.
like what if some plonk takes you out your bike flips 10 times and ends up in a pile of bits the other side of the track then catches fire.
I don't tend to think about these possibilities that much.
maybe I should maybe I shouldn't
:P
Old 09-Nov-2005, 12:08   #10
The clutch cover on Logyk's FWR 888 is machined...there is a pic in the 13th post down on this link here
[Edited on 9-11-2005 by Jools]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:29.
