Old 14-Nov-2005, 15:31   #1
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Wheel Sizes
How do you find your wheel sizes. Where do I measure from?
D
If I've done it right I would say front is 17x3.5, rear 17x5.75
Da
[Edited on 14-11-2005 by dave996]
Old 14-Nov-2005, 15:50   #2
Measure across the inside of the wheel well, ie where the bead sits
Old 14-Nov-2005, 15:57   #3
dave996's Avatar
Mood: Fed up...
Cheers mate
Old 15-Nov-2005, 08:33   #4
frazelli frazelli is offline
Mood: whatever!
My rear wheel width measures 5.75 inches should this run a 190 or 180 tyre?
The old tyre was a 190 which came with the wheels when I brought them so I'm not sure whether I should replace like for like or go for the 180?
They have not yet been fitted and are going on my 748
Regards Frazelli
Old 15-Nov-2005, 10:20   #5
dave996's Avatar
Mood: Fed up...
Mine is running a 190 at the moment.
Not too sure if a 180 would fit.
Old 15-Nov-2005, 12:35   #6
if its std 996 wheels 180 will be ok, thats what I have fitted anyway...
Old 15-Nov-2005, 18:38   #7
ziggi ziggi is offline
ziggi's Avatar
a standard 996 wheel is 5.5 inches and does fit a 180 section tyre well. 6 inch rim fits a 190 well but as for the 5. 75 rim, i don't think anyone here has mentioned the best fit for it. search for the wheel and tyre post by shazzam!
Old 17-Nov-2005, 16:25   #8
dave996's Avatar
Mood: Fed up...
Is it possible to powder coat or stove enamel magnesium wheels?
Old 17-Nov-2005, 16:35   #9
keefer keefer is offline
keefer's Avatar
only through people who know what they are doing with Mag.
its not as simple as other metals.
it requires a special coating before being painted, otherwise it will all just flake off.
best off contacting Dymag, although I found them to be a bit expensive
Old 17-Nov-2005, 16:49   #10
dave996's Avatar
Mood: Fed up...
Cheers Keefer.
I had them painted by a place up near Lincoln but I think they only did paint not powder coating.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:30.
