Old 07-Jan-2006, 20:38   #1
joe748 joe748 is offline
2002 998bp top speed?
what would you expect to get from a 2002 998bp? had mine flatout and only got 145mph (on a private road ofcourse )
i got more out of my 748 so i'm begining to think all is not right with it! althought it feels ok just lack of topend. it's totally standard as far as i know! just thinking i haven't checked the gearing yet, what is standard gearing for it?
cheers,
joe
Old 07-Jan-2006, 22:52   #2
psychlist's Avatar
Mood: Lucky? For some, maybe!
2003 Bip
Can't remember what size the std rear sprocket is but I had an indicated 157 with a 15 front and 154 with a 14 front sprocket, I'd expect someone with a bit lower "drag coefficient" (ahem!) to get more
Send a U2U to Skidlids, he'll know what the standard gearing is
Old 08-Jan-2006, 01:52   #3
cheers mate, will do.
i'm not to areodynmaic(spelling?) myself.....being 6'1 and 15 1/2 stone lol maybe thats the problem! should lay of the burger kings for a while
Old 08-Jan-2006, 02:05   #4
Totto Totto is offline
Get a 14tooth front sprocket on it , it takes ages to get anywere near top speed on std gearing ,the smaller sprocket takes a few mph off but it gets there before runing outa road (private)
[Edited on 8-1-2006 by Totto]
Old 08-Jan-2006, 02:40   #5
I will check my gearing but I know mine gets to 150mph very rapidly, not on a private road but they allow these sort of speeds in the IOM, probably go faster than that if held flat for the mountain mile with no traffic.
Mainly standard in the engine department except for full 50mm exhaust, got a PC111 USB but haven't fitted it yet as bike is laid up for the winter.
Old 08-Jan-2006, 10:46   #6
Carbon749's Avatar
Mood: I own a flame thrower
cheers,
joe
Would have thought you'd see 155mph eventually. Most have had the 15 tooth front sprocket swapped for the 14 tooth sprocket which will effect top speed. Other thing is that your comparing it to your 748 top speed, who says the speedo was accurate on the 748
Old 08-Jan-2006, 11:08   #7
How fast does it go around corners? You managed to do a corner at 150mph yet?
Old 08-Jan-2006, 12:20   #8
goes fast fast enough round corners andy......if i wanted top end i would have kept the fireblade..........187mph......who uses that on the road??
just wanted to know what it would do!
didn't say it was accurate, are u saying the 748 speedo isn't but the 998 speedo is accurate?? good luck with the new bike btw get sum pics up
got a 14 tooth front on order trevor, should be here next week.
thanks for the replys guys
Old 08-Jan-2006, 13:15   #9
Dont forget to check the ride height before and after ,if you need the gauge let me know or give me a shout when the sprocket is here and call down and i will help
Old 08-Jan-2006, 19:49   #10
I saw 160 on the clocks of Bob down the back straight at Donny before hitting the brakes for the esses
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:02.
