General Motorcycles only
Old 13-Jan-2006, 20:32   #1
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Serious problem
I might .... MIGHT... have dropped a small piece of rubber from my bell mouth seal down the injector bodies!!!
Now would this be a problem and do I need to take the engin apart or as it is just a small piece of rubber seal will it burn up and not be a problem
TTFN
dave
(smiley face with a dunce hat on)
Old 13-Jan-2006, 20:41   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Ummmmmm.......
Try taking the plugs out and the pipes off and turning it over on the starter to see if you can push it out.
At your risk. Of course...if it goes horribly wrong ....it's not my fault!
If it make you feel better, I was once doing an oil change on my 748SP when a small stone fell out of the fairing and into oil the filler hole. Italia took the **** out of me for weeks after that and that little episode cost me about £400!
[Edited on 13-1-2006 by twpd]
Old 13-Jan-2006, 21:50   #3
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
mmmmm,
depends how big this bit of rubber is.
If its a bit as in "tiny" sliver from the rubber o ring that goes around the belmouth as it clicks into the injector body, I would say you should be ok. It would burn up.
If its hard rubber. Or getting on for more than a tiny bit. I would say that it shouldnt be in there.
I would be looking for ways to try and get it out. After all, dropping things into the cylinder head is a no no, and really does go against the grain.
What ever happended to covering these sorts of holes when working on the bike? Good workshop practice.
Hope you sort it and dont spend to much money.
DC.
Old 13-Jan-2006, 21:52   #4
dave996's Avatar
Mood: Fed up...
It's the small piece from the o ring.
Everything had been covered up, I had just removed it all to attach the bell mouths.
Old 13-Jan-2006, 21:58   #5
DC DC is offline
DC's Avatar
Sods law ain it?
How long would you say?
Old 13-Jan-2006, 22:32   #6
dave996's Avatar
Mood: Fed up...
1.5cm
Old 13-Jan-2006, 22:39   #7
748S 748S is offline
Sent you u2u mate
Old 13-Jan-2006, 22:56   #8
dave996's Avatar
Mood: Fed up...
Originally posted by 748S
Sent you u2u mate
Hello mate, long time no speak.
u2u 2u
Old 13-Jan-2006, 23:40   #9
chris999 chris999 is offline
Mood: red and proud !!!!
what you need is RVI (remote visual inspection) and retrieval gear..
some garages have this sort of stuff (we use it !!)
a 5mm fibre scope with small retrieval taped to it could go in your plug hole and find and grab it .
i deal with olympus if you want i could talk to them to see if a rep could give you a "demonstration"on your bike
Old 13-Jan-2006, 23:48   #10
Harv748 Harv748 is offline
Harv748's Avatar
Dave...are you really trying to say:
'I might .... MIGHT... have dropped a small piece of rubber from my RUBBER MALLETT down the injector bodies!!!'
Sorry...few beers heavy, just couldn't resist:P
Didn't know you were getting the injector bodies powder coated also
To answer your question...I ain't got a friggin' clue
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:01.
