Old 31-Jan-2006, 14:14   #1
DSC Member AK AK is offline
AK's Avatar
you would just need to change the mounting bracket, cos one is a solid mount on the plastic tank, and the other on the metal tank is 2 bars. Otherwise should be ok to interchange tanks, as long as you take the pump with either one.
Old 31-Jan-2006, 14:16   #2
jed jed is offline
jed's Avatar
Thanks.
Old 31-Jan-2006, 14:42   #3
jed jed is offline
jed's Avatar
Monster tanks
Dose anyone know if the different tanks used on the 04 620 monsters plastic ones and metal ones are interchangeable?
Old 31-Jan-2006, 17:50   #4
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
They will interchange but the metal tank the pump fits though the top the plastic tank it bolts into the base,not the same pump.
Old 31-Jan-2006, 17:56   #5
paynep's Avatar
Mood: Wet wet wet
If anyone needs a steel tank, I have one from a 2002 620 going spare.
Its red, has a few small dents but will save risking a new one.
Cheers, Paul
Old 31-Jan-2006, 18:25   #6
AK's Avatar
thats why I said it was easier to take the pump that belongs to the tank with it. Tho you can swap them - its a bit of a fiddle, and not a quick job.
C
Old 31-Jan-2006, 18:29   #7
butch890 butch890 is offline
Mood: Enjoying Togdom !
you will also need to move the relay attached to the battery tray to fit the right tank,plastic tank its fitted on the lefthand side,metal tank its fitted to the back.
Butch
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:57.
