General Motorcycles only
Old 15-Feb-2006, 20:26   #1
Loz Loz is offline
Loz's Avatar
The right glue for the job
Did a quick search for what I wanted but I seemed to get stuck ...
Can someone please advise me the best adhesive for:
1. Fixing the trim to the edge of the screen on a 999S
2. Fixing a carbon fibre cover to the existing tank pad on a 999S
Thanks very much!
Old 15-Feb-2006, 20:29   #2
Redruth Redruth is offline
Redruth's Avatar
Mood: Fabulous
Copydex
Works for me - looks a bit messy but then I don't mind white gunky stuff seeping out all over the place
I really shouldn't have had that large gin
Old 15-Feb-2006, 20:30   #3
Davieravie Davieravie is offline
Davieravie's Avatar
Mood: Warmed up and ready to go
Impact adhesive.....if its done right...then it will never move
Old 15-Feb-2006, 21:11   #4
Loz Loz is offline
Loz's Avatar
Ruth
Thanks for your thoughts concerning the white stuff, I'll ask for a more detailed explanation on Friday.
Davieravie
I'm not sure how permanently I want either item stuck - impact adhesive might be a bit too much. Thanks for answering though.
Any other suggestions anyone?
Old 15-Feb-2006, 21:22   #5
Davieravie's Avatar
TUT TUT TUT.....and who says MEN have one tracked minds???
Old 15-Feb-2006, 21:25   #6
Davieravie's Avatar
Why would you want anything of the things that you want to glue to be not permanent? Doesn't make sense Loz??
Old 15-Feb-2006, 21:31   #7
Loz Loz is offline
Loz's Avatar
I suppose the screen trim isn't an issue, but I don't know how well the c/f tank pad will wear. If it ends up looking totally naff, I don't want to destroy the original tank pad underneath when I come to remove the c/f cover!
I'm trying to think ahead here, it's a new experience for me!
Old 15-Feb-2006, 21:38   #8
Davieravie's Avatar
Theres a will and way to remove any glue. Impact is the strongest. Super Glue will work on the tank pad....but Impact is probably best for screen trim. you dont want the wind lifting it do you??
Old 15-Feb-2006, 21:44   #9
Loz Loz is offline
Loz's Avatar
Davie, it occurred to me what effect the wind might have, hence my search for glue.
I'll try the impact adhesive for the trim and probably end up doing the tank pad too. Cheers for the advice.
Old 15-Feb-2006, 22:00   #10
Davieravie's Avatar
Make sure both sides are almost dry and stick em together......once its together then its together.... do the instructions as per tube/tin.... very very tacky both sides and it should stick no probs
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:07.
