Old 28-Nov-2013, 21:50   #1
badgerpilot's Avatar
Question Whips and chains
I lied about the whips but it got you looking!
I'm in the market for a new chain but not quite sure what to go for, can I have verdicts on:-
O rings
X rings
Plain roller
Soft links
Split links please
I know it's difficult for you lot, but try to keep it clean and sensible, thank you.
Scott #50
Old 28-Nov-2013, 22:05   #2
I use 'O' 'X' ring and soft link, there a bit stiff when cold but soon warm up.
Old 28-Nov-2013, 22:08   #3
coppersaucepipe coppersaucepipe is offline
Bikes: YZF750R, DD 'B' class monster #2
http://www.wemoto.com/bikes/ducati/m...y_duty_o-ring/
It comes with both sorts of links, I use the split link.
Old 29-Nov-2013, 06:21   #4
dunlop0_1's Avatar
Non O ring with a soft link. Never had a problem in 2 1/2 years.
Old 29-Nov-2013, 12:01   #5
same,,,,,, 4 years, then I had one snap,,, but then so did phil and he had a did xring? so go figure.
Old 29-Nov-2013, 14:30   #6
mark 999 mark 999 is offline
Bikes: Anyones
mark 999's Avatar
I use O or X ring, which ever is cheapest.
I use EK chains, usually off Ebay for about £40 to £50.
Started using split links after a failure at Oulton last season from a rivetted link and have had no issues since.
Old 30-Nov-2013, 07:11   #7
yendor yendor is offline
Matt Phils chain loss at brands was a Nog chocky no probs since.
Old 30-Nov-2013, 11:37   #8
Having helped setup and maintain 4 DD bikes, 3x583's and 1x620, over the past 5 years, always fitted plain race chains with soft links, never had one fail. The main thing is the fitting of the soft link, always measure the original link and fit the soft link to measure the same, I have always used a Chain Whale to fit them. Maintenence, is key to the longevity of a plain chain, it Must be lubed after every race, practice, qualy etc, otherwise the pins and rollers will dry out and wear, leading to failure.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:40.
