Old 08-Dec-2013, 17:01   #1
Madness Madness is offline
Gearing
I'm going to fit a new chain and sprockets to my 620, I understand to get the most out of the Ducati the gearing has to be spot on.
Before the season starts I'm not going to be out much testing so any pointers to what gearing works where would be a real help
Old 08-Dec-2013, 17:59   #2
dunlop0_1's Avatar
5 speed 14/46
6 speed 15/46
Old 08-Dec-2013, 18:30   #3
Thanks for the info, is that what your need for all tracks? I was thinking you would need to change it throughout the season at different circuits .
Has anyone got any information on internal gear ratios please
Old 08-Dec-2013, 18:39   #4
Neil won the Class A championship a couple of years ago so knows what he's talking about
as for gearing chartsthere should be a couple of my spreadsheets about on the site
Old 08-Dec-2013, 19:03   #5
dunlop0_1's Avatar
Without telling you how to suck eggs. Please don't get to involved in gearing etc as in my opinion you don't stand to gain/loose much anyway. Some people do change gearing for different circuits but it never bothered me.
Check out Kev's gearing chart it's very good.
Old 08-Dec-2013, 19:11   #6
Ok that's great, I'll get a chain and them sprockets and see how it goes.
Thanks for the advice, I'll take a look on the site for the charts
Old 11-Dec-2013, 08:26   #7
Spjallen Spjallen is offline
I messed about in the first year changing front and rear sprockets all the time and it was a total waste of time. Find a setup that works then use it - ie use Neils!
Old 11-Dec-2013, 17:56   #8
coppersaucepipe coppersaucepipe is offline
Bikes: YZF750R, DD 'B' class monster #2
I run 15 48 because last time I tried, I couldn't budge the front sprocket to swap it for a 14.
Old 11-Dec-2013, 20:30   #9
milesaway milesaway is offline
Bikes: 900ss 600ss xr400
milesaway's Avatar
gearing commander
this is a good site that if you put in make model year etc will give speeds at any gear/revs at standard gearing and also any front/rear sprocket combo you enter- gives good idea what any changes will do what once you have a starting point- -
i got small select of 2fronts + 3rears and made table of each combo at just below red line so from here so could quickly see difference they all make
link below;
http://www.gearingcommander.com/
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:51.
