Old 25-Feb-2006, 18:44   #1
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Help - fitting belly pan
Im trying to mount my belly pan to the bike so I can remove to side panels seperatley at meets.
Can anyone tell me and/or post some pics of how the belly pan attaches to the bike ? I was supplied with 3 brackets, I can see one mounts to the rear brake master cylinder but im struggling on the others !!
Nat
Old 25-Feb-2006, 19:43   #2
neil748r neil748r is offline
Are they race or road fairings i.e. are you using the sidestand?
If it's race bodywork with no sidestand then you only need 2 brackets, 3 if using the sidestand. In both cases 1 bolts on outside of the rear brake master and the other(s) bolts on using the spare 10mm threaded hole on the engine casing just back from where the sidestand bolts on.
Only thing is, the left side bracket(s) are completely different between race (1 bracket) and road (2 brackets).
I've got both types kicking about somewhere so if you're stuck, give me a couple of days to locate them and I'll take some pics for you.
Hope that's of some help,
Neil.
Old 25-Feb-2006, 20:22   #3
aka.eric aka.eric is offline
Any help?
Old 25-Feb-2006, 20:23   #4
Need to zoom in a bit with this one
Old 25-Feb-2006, 20:25   #5
Not sure what the Dzus is doing in this one
Old 26-Feb-2006, 11:21   #6
Nattyboy's Avatar
Thanks guys - neil - its a race fairing (no sidestand cutout) - pics would be appreciated !!
Nat
Old 26-Feb-2006, 12:18   #7
No problem Nat,
Pretty sure I remember where the brackets are so all being well I'll get some pics for you tomorrow.
U2U me your email address and I'll send them direct.
Cheers, Neil
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:10.
