Old 26-Feb-2006, 22:23   #1
urga urga is offline
front headlights plunge monkey into darkness!!!
Hi Can anyone shed some light on this problem?
Travelling along with my lights on as usual....went to switch to hi beam and nothing!no lights at the front at all!!Instrument panel was still lit.Rear was still lit.But nothing at the front.The Flash switch still worked and continued home with my finger on that.
Checked the fuses/bulbs and they all seem fine.
Could this be the switch.It's a 2003 uk model so it has the switch on the r/h and full/dip on the l/h.
Any ideas?
Old 27-Feb-2006, 07:13   #2
Could be the switch on the l/h bar.Nip it off and check for corrosion.Follow the cables down the bars and check all the wiring conectors.
If you find nowt,it could be the ECU.Get it checked by a dealer.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:22.
