Old 05-Mar-2006, 20:25   #1
i porter i porter is offline
Gear Indicator
Has anyone fitted one of those mechanical gear indicators to there dash. Does it work and is it easy to fit.
Old 05-Mar-2006, 22:24   #2
Harv748 Harv748 is offline
Harv748's Avatar
Yes...and Kind of!
It depends on the year of your bike. My early 1995 916 is one of the few models that prove a little tricky to wire up. Its missing a piece of the circuitry required to activate the neutral side of the indicator. Without this you can't program it.
I got around it by installing an extra 3 pin relay, which sits behind the nosecone, that now gives me the required input. This was done with the aid of the technicians at Digitool who where very helpful.
I think if your bike is 1996 or later, you should be OK, and if so then they are very easy to fit.
Old 05-Mar-2006, 23:18   #3
Thanks. Mine is a 996R 2001 model. Ill give it a go.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:53.
