Old 04-Apr-2006, 00:07   #1
jed jed is offline
jed's Avatar
Suspension or power?
Im trying to decide if i should buy a Power Commander USB III+ K&N and get it set up on a dyno or upgrade my rear shock to an Ohlins. Both look like they will cost around £400 - £500.General opinions,which would be best to have on its own for now?
Old 04-Apr-2006, 00:34   #2
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
unless you know the upcoming tracks like the back of your hand, i think you'd get a better boost in results from a couple of track days at said tracks
if not id probably go for the shock
Old 04-Apr-2006, 00:52   #3
Jed judging by your lap times at Cadwell I doubt if the shock is holding you back unless you have serious ground clearance problems.
Maybe worth getting it on a dyno and checking the fueling before spending out on the tuning parts.
As suggested maybe more track time would be a better use of the money.
Bit hard to comment on bike as I don't know whats been done to it or seen what its setup is like.
Which is something than can be discussed at Brands on the Saturday evening
Old 04-Apr-2006, 00:52   #4
Suspension - if your bike doesn't handle no amount of bhp will fix it.
Old 04-Apr-2006, 01:23   #5
domski's Avatar
Definately suspension first.
We ran totally stock showroom spec (2005 Monster) suspension at Cadwell and I thought it was very good actually. The rear was a bit soft (but nice) and I did deck the pipes out, but that can be dialed out.
As it happens, Chass has put the Ohlins out of his 916 in it now
I wouldn't think you'd tell the difference between Ohlins and a standard shock, that's not a dig at you, I wouldn't know unless it was very bad.
I would just spend money on tracktime and when you're held back by the suspension (and you'll know) then buy suspension upgrades.
I don't think a PC3 makes that much difference.
Our bike out dragged bikes with more toys on, and it's only got an air filter and end cans.
Try harder
[Edited on 4-4-2006 by domski]
Old 04-Apr-2006, 09:28   #6
dickieducati's Avatar
if you are running stock suspension and it needs sorting brands will show it up for sure. if its to soft or the ride height is too low you will be decking cans, belly pan, and pegs round druids and clearways and it will definitely affect your times. if its ok then look at time on the bike for experience.
Old 04-Apr-2006, 09:49   #7
Chris Wood's Avatar
Time on the bike...my major investment this year is..tracktime!!!
Good example is Glen on Tonio's bike at Cadwell, it's bog standard! doing 148's!!!!
Old 04-Apr-2006, 09:56   #8
fil2 fil2 is offline
fil2's Avatar
Mood: is it still wet
agree with that man 100%
Track time is the key.....................
Old 04-Apr-2006, 12:55   #9
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
In the order, I think we need:
1 - a lot of track time
2 - good suspensions
3 - balls
4 - a bit more power
Old 04-Apr-2006, 15:22   #10
couchcommando's Avatar
Mood: ooooh
Has to be track time, there are plenty of standard suspension bikes finishing in the top 10.
Maybe concentrate a bit on getting the perfect gearing at each track too
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:01.
